Author Topic: 555 timer IC  (Read 5558 times)
Offline polar bear6Topic starter
555 timer IC
« on: April 24, 2006, 08:25:50 PM »
hey.
i just bought 50 555timer IC's for about 3$, and the only thing i know i can use em for is photovore.
i found a neat schemetic.
 http://costaricabeam.solarbotics.net/Circuits/Vores/555%20Photovore.png
in Junkbots, bugbots and bots on weels (a BEAM robotics book)  it said that it could be use to shitloads of things, but i only found the photovore...
anyone know any other neat stuff I can use them for?
damn, im gonna make me one of theese: http://s95417013.onlinehome.us/ktekx/5.htm
Re: 555 timer IC
« Reply #1 on: April 25, 2006, 01:37:20 PM »
The 555 timer
http://www.uoguelph.ca/~antoon/gadgets/555/555.html
has a billion uses . . .
http://home.cogeco.ca/~rpaisley4/LM555.html
The best use for robotics I can think of is for PWM (which also has hundreds of uses).
I always wanted to try and figure out how to use a 555 to control a servo without a microcontroller, but have been too busy/lazy to bother with it.
http://www.repairfaq.org/filipg/RC/F_Servos.html
Re: 555 timer IC
« Reply #2 on: April 26, 2006, 10:00:20 AM »
i kindah forgot what PWM was, can you plz explain?
Re: 555 timer IC
« Reply #3 on: April 26, 2006, 10:19:07 AM »
Pulse Width Modulation
Basically a square wave, scroll down to the last picture:
http://www.societyofrobots.com/schematics_h-bridgedes.shtml
You basically turn something off and on really really fast, so instead of being fully on or fully off, you get something in between. This way you can get analog control through pure binary control.
Its like turning a motor on and off really fast by hand so that it isnt running full speed, but it is still moving. That is PWM. Of course it is better with millisecond control, like with a microcontroller, or a 555 timer  :P
And of course, the ratio of on to off pulse widths determines the speed of your motor, or brightness of your lightbulb, and so on.  8)
Oh and just to not confuse you, servo's are not powered by PWM (at least not by the user). Instead you send PWM just as a control signal that its own internal circuitry interprets. A particular width instead determines the angle the servo is at, or speed at which it rotates if modified, through its own internal feedback control system thingy.
« Last Edit: April 26, 2006, 10:22:46 AM by Admin »
Offline bibinjohn
Re: 555 timer IC
« Reply #4 on: August 01, 2006, 02:08:43 PM »
555 cannot source enough current to drive a motor. IF you want pwm using 555 then use astable circuit, instead of Ra and Rb use one pot with one end on Vcc, other end on pin6 and the variable end on pin7. Use one diode with one end on pin6 and other on pin7. Use H-bridge to drive the motor.
Bibin John
www.bibinjohn.tk
« Last Edit: August 01, 2006, 05:13:03 PM by Admin »
Last post April 10, 2010, 05:56:17 PM
by corrado33
Last post September 28, 2010, 06:04:15 PM
by kidwidget
Last post October 19, 2010, 01:22:17 AM
by knossos
Last post February 16, 2012, 08:00:02 PM
