Author Topic: What is this kind of programming called?  (Read 1296 times)
Offline Razor ConceptsTopic starter
« on: December 29, 2008, 11:35:06 PM »
Say you have a MCU that blinks a light. You press a button 7 times, the MCU stores "7" and blinks 7 times. This is a sort of programming, but what is it called? I'm pretty sure there is a name to it but I can't get it out of my head. External programming?
Offline pomprocker
Re: What is this kind of programming called?
« Reply #1 on: December 30, 2008, 02:36:02 PM »
that sounds like a recursive function?
Offline izua
« Reply #2 on: December 30, 2008, 10:33:18 PM »
I'd call it user unfriendly :D
Offline cosminprund
  • Helpful? 8
« Reply #3 on: December 31, 2008, 04:25:02 AM »
@pomprocker
That's not a recursive function, unless you work real hard to ignore the obvious implementation (simple loop) and go with an implementation that's likely limited by the MCU stack.
@izua
Agree!
@Razor Concepts
Why do you think it needs to have a name? If it matters my car alarm system supports a similar way of programming it. They call it "Valet Button Programming". I assume you're thinking of a name from the end-users perspective, not the name for the programming technique used to implement the behaviour.
Offline cosminprund
  • Helpful? 8
« Reply #4 on: December 31, 2008, 04:56:22 AM »
@Razor Concepts
If the 7 click - 7 blinks was just an example, you're probably looking for "finite state machine".
Last post February 10, 2009, 10:02:27 PM
by izaktj
Last post April 08, 2009, 12:37:10 AM
by SmAsH
Last post December 15, 2009, 04:07:03 PM
by andreiipascalin
Last post March 11, 2012, 08:30:07 PM
by davidhere40
