Author Topic: LED control board  (Read 2178 times)
Offline DanCFTopic starter
LED control board
« on: February 21, 2007, 08:56:14 PM »
I am looking to animate a matrix of LEDs. I am looking for something similar to a microprocessor, where there are multiple channels, however instead of it controlling the wavelength of the third wire and keeping the voltage on the first two constant, I am looking for just two wires per channel on which the voltage can be adjusted from mybe 0-4 volts.
Offline Hal9000
Re: LED control board
« Reply #1 on: February 22, 2007, 05:37:37 AM »
I think I got lost as soon as you said wavelength. Elaborate.
Offline thesiliconhorizon
« Reply #2 on: February 22, 2007, 07:09:50 PM »
try this one, itll run lotsa leds with the darlington array output..
also it can do PWM to run LEDs if you like...  (upto 2 channels)
and you can addon a devantech I2C servo controller to control upto 21 more lines of .5-2.5 mS LED pulses (servo pulses...)
so whatever your needs... check it out!!
but the darlington array is great for running a LED matrix.
www.thesiliconhorizon.com
Offline 555 timer chip guy
« Reply #3 on: March 05, 2007, 09:38:28 AM »
Here is a schematic for a counter circuit with varying speed, and if you wont to control the voltage on one pin gust add a transistor and a pot to that pin to control it.Cum to think of it the transistor and the pot could be used on a microcontruler to.
« Reply #4 on: March 05, 2007, 09:42:38 AM »
sorry about the name of the schematic that part of the circuit was from a nother circuit that I was designing.
Last post July 22, 2007, 10:44:11 PM
by HDL_CinC_Dragon
Last post October 17, 2007, 08:21:55 PM
Last post January 23, 2008, 09:00:28 PM
by Trumpkin
Last post November 12, 2008, 12:49:53 AM
by pomprocker
