Author Topic: Are you good at Google SketchUp?  (Read 3070 times)
Offline Thomas CountzTopic starter
« on: December 30, 2008, 11:10:02 PM »
If you are, I was wondering if you happen to have a model of solarbotics GM8 motor...?
If not, and you can make one, and it wouldn't take you much time or effort, I would really appreciate it.  ;D
Here are the specs (they're for the GM2 motor, because solarbotics does not have the dimension for the GM8. I hope they're the same  :-\)
Measurements are in mm
http://www.solarbotics.com/assets/datasheets/solarbotics_gm2_metric.pdf
-Thank you in advanced  ;D  ;D  ;D  ;D  ;D
Offline nanobit
Re: Are you good at Google SketchUp?
« Reply #1 on: January 01, 2009, 06:57:55 PM »
am sorry I tried, but there is not enough dimensions in that pdf to make one
« Reply #2 on: January 01, 2009, 07:06:46 PM »
eh....damn solarbotics....haha
Thank you for trying.  :)
Offline paulstreats
« Reply #3 on: January 01, 2009, 07:17:57 PM »
Im not making it because i cant be bothered, but that datasheet seems to have every concievable measurement that anybody would need so the other poster just hasnt tried either.....
why not make it yourself?
« Reply #4 on: January 01, 2009, 07:21:33 PM »
No, I am trying to make the model myself, but it's coming along very crude and doesn't exactly serve the purpose that I'd like it to...so I figured, if someone has a decent skill at using SketchUp, and they don't mind, why not ask?
« Last Edit: January 01, 2009, 07:22:15 PM by Thomas Countz »
Offline nanobit
« Reply #5 on: January 03, 2009, 11:37:24 AM »
I could make the gear box no problem, but the motor had no dimensions. I was trying to make it in SolidWorks, but I see what you are saying, if I just go by using the image I think I can do it.
By the way how accurate does this have to be? What is this for?
  • Helpful? 111
« Reply #6 on: January 03, 2009, 12:23:38 PM »
If it helps: here is a Solarbotics GM9 motor.
« Reply #7 on: January 03, 2009, 12:42:52 PM »
It just has to be recognizable really. It's just for a personal project that I'd like to have a model of because I don't know if I want to use the Solarbotics GM8 motor or a HiTec HS-311, I think I'm going to go with the servo however, for a lot of obvious reasons, but if you want to continue working on the model, it would be appreciated, but I don't need it as urgently per se.
Offline lanamor
« Reply #8 on: January 07, 2009, 06:56:24 PM »
I just leaned sketchup lst week; but here is the GM8 I made. Morked ok for me, maybe you can use it too.
« Reply #9 on: January 07, 2009, 07:00:22 PM »
looks good. Can you upload it to Google Warehouse, and then post up the link to the Google Warehouse page for the component. I want to upload it to my Robotics Parts Collection - http://sketchup.google.com/3dwarehouse/cldetails?mid=9f6353632a39809a54179885bd086c8a&prevstart=0
Thanks,
Eric
Offline lanamor
« Reply #10 on: January 08, 2009, 05:36:23 PM »
If you search for GM8 fro mthe 3d warehouse you'll find it.
« Reply #11 on: January 08, 2009, 06:57:46 PM »
Muchos Grasias  ;D
« Reply #12 on: January 26, 2009, 11:56:15 PM »
Another trick you can do is search the part libraries for something that looks similar, then manually change the dimensions and tweak the looks.
