Author Topic: $50 uart- compiling error  (Read 3044 times)
Offline ed1380Topic starter
« on: December 31, 2008, 04:17:10 PM »
i did the uart tutorial step by step, but it wont compile.
if i cut and past the original $50 robot code it works great. but if i add the uart stuff to it, it gives errors.
using no code between while and return, gives the same error as using minimal code. heres a screenshot. the error line is the  { after return
ive activated and deactivated every bit of the initialization stuff and it only gives more errors
heres what i have
heres teh big pic http://i43.photobucket.com/albums/e398/RussianCommy/screenie.jpg
« Last Edit: December 31, 2008, 04:18:05 PM by ed1380 »
  • Helpful? 107
Re: $50 uart- compiling error
« Reply #1 on: January 01, 2009, 04:34:13 PM »
The 'return 0;' on line 62 is withinside your main loop !!!
You need to move it down a line or two so its after your closing '}' for the while statement
« Reply #2 on: January 02, 2009, 11:29:12 PM »
why couldnt someone answer 12 hours earlier
i burned my avrisp
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #3 on: January 02, 2009, 11:50:25 PM »
They aren't so fragile.... are they....
I haven't burned any of my programmers so far....
Cheers!
« Reply #4 on: January 03, 2009, 09:40:54 AM »
idk. IIRC the AVRISPII are the ones with overvolt protect.
i was messing around with mosfet drivers on the breadboard, and kinda connected the 12v powerbus wires with the 5v bus. idk about the atmega. i got a couple more of those, but poor avrisp
Offline HDL_CinC_Dragon
« Reply #5 on: January 03, 2009, 10:29:02 AM »
The bracket '}' on line 63 is the closing bracket for the while loop. The return is definitely inside the while loop... unless I missed a bracket somewhere?
-EDIT-
Any chance you could attach the code you are using, ed?
« Last Edit: January 03, 2009, 10:32:22 AM by HDL_CinC_Dragon »
United States Marine Corps
Infantry
Returns to society: 2014JAN11
« Reply #6 on: January 03, 2009, 03:06:49 PM »
everything is good now. it was that stupid bracket
Last post July 17, 2008, 09:54:57 AM
by pomprocker
Last post February 17, 2008, 09:24:45 AM
Last post November 05, 2010, 10:51:23 AM
by Fleet
Last post November 16, 2009, 07:34:31 PM
by Loco Robo
