Author Topic: RFID Door lock  (Read 9360 times)
Offline gamefreakTopic starter
  • Robo-Enthusiast
RFID Door lock
« on: February 22, 2007, 03:50:25 PM »
hello all.
I am currently working on a RFID door lock and so far my current idea for the lock is a solonoid.
But is it possible for the solonoid to move in to let the door close?
Also if i use a normally open solonoid can i push the solonoid arm in without damaging it?
Offline ed1380
Re: RFID Door lock
« Reply #1 on: February 22, 2007, 08:23:47 PM »
Yes you can move the rod. Just bevel the rod so that it looks like the rod on a door handle.
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #2 on: February 22, 2007, 08:40:04 PM »
Now how do i bevel something? Just sand/cut it to the shape?
Also a normally open solenoid is a pull type right?
What is the stroke? i found this website:http://www.solenoids.com/linear_solenoids.html
But what does the stroke mean?
« Last Edit: February 23, 2007, 07:53:22 AM by gamefreak »
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #3 on: February 23, 2007, 11:48:50 AM »
Another solonoid i was looking at it:http://solenoid.com/images/solpdf/st1325n.pdf
But im a little confused on the Duty thing. 100% has the most resistance least force and least wattage(lost?) and 10% has most force least resistance and most wattage(lost?)
So for a door i probably want 100% duty because i dont need force and it lets off the least heat?
Offline ed1380
Re: RFID Door lock
« Reply #4 on: February 23, 2007, 12:14:31 PM »
Is it a magnetic silinoid that will pull in the rod to let the door open or one where the rod is threaded and a motor pulls it in by spinning
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #5 on: February 23, 2007, 12:43:03 PM »
i think a magnetic because it is simplier by when i get a valid card i apply the voltage and it will unlock the door.
Offline ed1380
Re: RFID Door lock
« Reply #6 on: February 23, 2007, 03:05:15 PM »
You could take an existing door handle setup, and replace the handles with a servo.
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #7 on: February 24, 2007, 04:35:59 PM »
i thought about that but i cant figure out how i would hook it up.
Any ideas?
Offline ed1380
Re: RFID Door lock
« Reply #8 on: February 24, 2007, 05:51:12 PM »
or maybe a deadbolt. just remove the deadbolt handle, and ghetto a servo on. It would depend on what servo and what door handle it is.
Re: RFID Door lock
« Reply #9 on: February 24, 2007, 05:54:37 PM »
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #10 on: February 26, 2007, 08:10:29 AM »
The servo plasted on to the latch would work, but it doesnt look very good, i'd rather have it all hidden inside the door or not have it extruding those extra two inches by attaching the servo.
Also if i had it go back to locked before the door closed then the door would not lock shut.
« Last Edit: February 26, 2007, 09:59:33 AM by gamefreak »
Re: RFID Door lock
« Reply #11 on: February 26, 2007, 10:07:56 AM »
the CMU robotics club used to have a servo driven door lock similar to this. we had a big red button you can push to manually unlock/lock the door, plus a magnetic card swipe outside that unlocks two doors for a short time period, and logs your visit.
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #12 on: February 27, 2007, 09:35:41 AM »
I geuss i'll change my overall plan so that it could be a lock for a safe or something and not to get into or out of a building, my reader and card arrived yesterday from parallax and i hooked it up so that first scan will open the servo and second scan will close it, but since its a continuos rotation if my progect runs out of power halfway through rotation then it will be messed up
Offline ed1380
Re: RFID Door lock
« Reply #13 on: February 27, 2007, 02:44:37 PM »
i don't know if this will work in your situation, but maybe have the deadbolt have a spring pulling it locked, and the servo works against the spring to open it. if power fails the spring should be strong enough to close the deadbolt. but if the door is open atm then that wont be good.
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #14 on: February 27, 2007, 02:54:26 PM »
So far i seems that my original idea(the solenoid) would be the best, but the ony thing i know is that i need a pull type that is small enough to fit inside of the door or the door frame. I have a "Parallax Board of Education, USB" and it gives up to 5 volts regulated, so i know i cant exceed that, another thing is that this will probably have to be battery powered so i need to have high current batteries(i think) in order for this to even be remotly possible without the batteries dieing after one use.
If someone could explain Stroke and Duty Cycle to me then i could get solenoids to work, also if i could get a link to batteries that might handle say 100 uses with the:BS2 "http://www.parallax.com/detail.asp?product_id=BS2-IC", RFID Reader Module "http://www.parallax.com/dl/docs/prod/audiovis/RFID-Reader-v1.2.pdf", and the solenoid, then i might be in buisness.
One solenoid i ran across at http://w2s.solenoids.com/ledx/ds/LXEZR/LXEZR2e.lasso?pcode=L214 is the .5 by .5 STA Pull has a speed of 4 milliseconds to move .5 millimeters with 100 percent duty(i think always on) and a force of 4 OZ at about 1 millimeter
Am i understanding that right because that sounds very small and short, but it might work for a door prototype....
« Last Edit: February 27, 2007, 03:15:40 PM by gamefreak »
Offline JesseWelling
  • Only You Can Build A Robot!
Re: RFID Door lock
« Reply #15 on: February 28, 2007, 03:19:54 AM »
what about chain driven from a servo that's embedded into the door?
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #16 on: February 28, 2007, 06:39:45 AM »
Doors are only about an inch thick and servos are an inch and a quater or an inch in a half depending where you measure from, so you would have the horn stiking out, which might be helpful, but with a chain anyone could just break it or something, Also the point is not to unlock the door, but to unlock and lock it in a way that you can only do if you have card, if they broke the chain or forced it to turn then anyone could get in.
Re: RFID Door lock
« Reply #17 on: February 28, 2007, 10:54:25 AM »
Solenoids tend to have a small travel distance . . . you will have to shop around for awhile. My vote is for the servo on deadbolt idea :P
As for your power concerns . . . you can have both plug in power, but also battery backups in case power goes out. Also, you can put a timer on it, so say if nothing happens for an hour, it will reset itself (look up watchdog timers), and relock the door. For something like this, you want backups.
Also, for the robotics club door, after the system locks the door, the servo turns off. So if say the system fails, you can still open the door with a normal key.
Multiple backups are good :P
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #18 on: February 28, 2007, 04:36:47 PM »
so your saying to buy a normal door handle with a lock, remove one side, attach the servo to that side, and then it should work?
Re: RFID Door lock
« Reply #19 on: February 28, 2007, 07:54:52 PM »
The servo rotated the deadlock. Just attach the servo to the part you rotate to lock the door. May or may not be the best method, but the method I mentioned worked very reliably.
Oh, we also put a small buzzer on it that buzzed when you swiped the card. Good feedback to know its working properly.
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #20 on: March 02, 2007, 11:48:07 AM »
Alright, as soon as my RFID reader rearrives then I can then set up the deadbolt and servo, Since i have free reign of all the machines and scrapwood in the woodshop then i can build a small door and a holder for the servo and deadbolt.
Now all i need is a battery....
« Last Edit: March 02, 2007, 12:51:47 PM by gamefreak »
Offline dunk
Re: RFID Door lock
« Reply #21 on: March 02, 2007, 02:16:57 PM »
so all the way through this you have been talking about putting the actuator inside the door.
have you considered putting it inside the door frame?
it would allow for a far bigger mechanism.
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #22 on: March 02, 2007, 04:06:53 PM »
actaully yes, when i first saw the door latch pictue that was my idea, so far my shop teacher and I are trying to figure out the placement of everything.
Alright now for a battery... I was thinking of a Li-po, Li-Ion, or Nicad battery because of there higher current and the power consumption of my circuit, would any of these work?
« Last Edit: March 05, 2007, 12:44:55 PM by gamefreak »
Re: RFID Door lock
« Reply #23 on: March 05, 2007, 09:00:50 PM »
you probably would want a NiHM type so its long lasting, cheap, and easy to recharge . . .
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #24 on: March 06, 2007, 10:25:07 AM »
Now on the links i gave for the Basic stamp and RFID reader, the power consumption is 93 MAh i think, so that means with a battery of 2300 MAH i can last 24 hours
Am i right?
Re: RFID Door lock
« Reply #25 on: March 06, 2007, 10:55:31 AM »
93mAh would be totally incorrect if you also wanted to power the servo with the same battery . . .
but yea, 2300mAh/93mAh = 24.7 hours
does the basic stamp have sleep functions (low power draw do nothing but wait mode)?
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #26 on: March 06, 2007, 11:42:25 AM »
Yes i know i didnt count the servo but since i dont expect it to run all them time im not to worried about its power draw.
Yes the basic stamp does and so does the RFID reader if i but them both in sleep mode then.... i would use 10.5 MaH and then bring up my battery life to almost 21 days,
the basic stamps leep mood is 5 uA and the modle is 10 mA
I dont know how much current the servo uses because the spreadsheet only gives me the volatge it can handle.
One thing i could do is say every two second turn off the RFID reader module and then turn it back on two seconds later and that should add more life to the batter due to the fact that im taking 80MaH out of the usage for 2 seconds
Due to the fact the the board has a jack for power other then a 9 volt battery and i dont see any batter packs with a jack i will have to attach my current battery choice of 8.4 volts and 2600 mAh to it, but is this good for the electronics or will it not make a difference?
« Last Edit: March 06, 2007, 12:54:33 PM by gamefreak »
Offline dunk
Re: RFID Door lock
« Reply #27 on: March 06, 2007, 03:08:33 PM »
so servos use quite a lot of power whether they are moving or not.
you can get round this by switching on the power to the servo using a MOSFET only when needed.
i haven't actually played with sleep mode on any microcontrollers but i think you wake them using an enable pin.
what about your RFID reader? can it detect when a card is in front of it while in sleep mode or will it need you to press a button?
if it can detect a card from sleep mode maybe it has an output you can use to wake your basic stamp when it does.
which board has the 9V jack? i'm guessing that's the RFID reader right?
i'd imagine 8.4 volts should work ok.
your basic stamp and servo will want around 5 Volts.
if you want maximum battery life i'd recommend a switching power regulator to drop your 8.4V to 5V.
you can build one using a LM2574 pretty much straight from the datasheet found here:
http://www.national.com/pf/LM/LM2574.html
switching step down voltage regulators are far more efficient than other types.
happy building!
  • Robo-Enthusiast
Re: RFID Door lock
« Reply #28 on: March 06, 2007, 04:54:32 PM »
my board with the basic stamp on it, its called the Board of Education and its from www.parallax.com
No the RFID reader can only read when it is in active mode so the only way to save energy is swithing it on and off.
Im not sure about the basic stamp and i dont have any MOSFETs, if power becomes a major problem i'll go to radioshack and buy some to enable and disable the servo
Re: RFID Door lock
« Reply #29 on: March 06, 2007, 10:19:59 PM »
another place to buy a switching regulator
http://www.dimensionengineering.com/DE-SWADJ.htm
but the problem with any regulator is really low efficiency so you should avoid it if you can
Last post March 01, 2009, 04:54:20 PM
by Razor Concepts
Last post September 16, 2010, 07:31:36 AM
by waltr
Last post August 01, 2011, 05:52:55 PM
by corrado33
Last post March 16, 2012, 09:38:40 PM
