Author Topic: 12v variable slide resistor  (Read 2022 times)
Offline cooldogTopic starter
« on: January 03, 2009, 07:45:17 PM »
okay guys i was wondering if i have a simple circut of a 12v motor and a car battery (12v) with a switch and i put a 12v variable slide resistor in the circut would i be able to control the motors speed?
if what i am saying is true does anyone know where to get a 12v variable slide resistor?
-admin
favorite web sites
http://www.instructables.com/
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
Re: 12v variable slide resistor
« Reply #1 on: January 03, 2009, 08:26:27 PM »
yes there is....
Google for LM317 speed controller
Cheers!
« Reply #2 on: January 03, 2009, 10:03:51 PM »
-admin
favorite web sites
« Reply #3 on: January 03, 2009, 10:07:39 PM »
Depends on how many amps your 12v motor will pull. The one you listed is good to 5 amps
« Reply #4 on: January 03, 2009, 10:18:43 PM »
would that be max 5 amps from the battery or that my motors draw
-admin
favorite web sites
« Reply #5 on: January 04, 2009, 09:42:26 AM »
The LD1585 will only do for a small('ish) motor.
It can handle around 2W un-sinked and with a large heat sink around 25W tops.
Regulating it to eg. 6V will make it drop 6V (actually a bit more, since the terminal voltage is more than 12V).
Un-sinked this equates to 2W/6V=333 mA
With perfect heat sinking it will be 25W/6V = 4,17A
Regulating the output further down will only worsen this to around 166 mA and 2,1A respectively.
(It's all in the datasheet).
Offline Trumpkin
« Reply #6 on: January 04, 2009, 09:43:06 AM »
That your motors draw.
Robots are awesome!
« Reply #7 on: January 04, 2009, 09:45:04 AM »
« Reply #8 on: January 04, 2009, 10:04:57 AM »
Here is something far better http://www.dprg.org/tutorials/2005-11a/index.html
that looks like a good circut however i looks like it need a lot of external parts
i would prefer just a off the shelf ready made circut
i think that i am moving more toward this option
thanks anyway but i would like to use something for a bigger motor so i can use it in future projects
-admin
favorite web sites
« Reply #9 on: January 04, 2009, 10:37:50 AM »
Then you really need a PWM circuit, as a linear solution has too much loss (i.e. heat).
You should be able to buy a ready assembled PWM solution, although it might be a bit expensive - perhaps you can advertise for someone here to build the circuit for you, so that you just have to connect power, motor and a potentiometer (eg. your variable slide resistor).
If you want to take that route, stating where in the world you live is not a bad idea.
« Reply #10 on: January 04, 2009, 12:34:33 PM »
well i live near toronto canada
-admin
favorite web sites
Last post February 09, 2010, 12:34:58 PM
by galannthegreat
Last post February 24, 2010, 08:33:23 PM
Last post May 12, 2010, 05:19:04 AM
Last post September 01, 2011, 09:00:05 PM
by Melcin Powell
