Author Topic: Interesting robot base?  (Read 2564 times)
Offline NyxTopic starter
« on: February 22, 2007, 11:57:06 PM »
Just wanted to share this with you... I found this hummer ride on toy online:
http://www.shop.com/op/~Little_Tikes_Hummer_Black-prod-36218636-48525441?sourceid=298
The thing is 4 feet long, and has its own power source. It's obviously too weak for you to ride on, but if it can carry two kids, it can probably carry a bigger battery, a laptop, and then some more equipment. It uses 12V power and should be pretty easy to set-up... Would basically need a way to control the steering, and this could make a good robot base. It has 14" wheels and can go up to 5 MPH.
Update: the maximum weight capacity is actually rated at a whole 130 lbs and it has storage space behind the seats... I'm starting to seriously consider this for my robot because of its hugely practical aspect. The only downside is that it would look a bit silly ;)
« Last Edit: February 23, 2007, 12:06:37 AM by Nyx »
Offline SomeSaba
Re: Interesting robot base?
« Reply #1 on: February 23, 2007, 12:11:29 AM »
If you are considering that, you can also consider cheaper ones on ebay for example:
http://cgi.ebay.com/Kids-ride-on-electric-car-Quad-motorcycle-lots-of-power_W0QQitemZ330089733020QQihZ014QQcategoryZ11746QQrdZ1QQcmdZViewItem
that is one of many choices, but its weight limit is 65lbs
Also steering the car is a manual turn of the steering wheel, so that issue would also need to be addressed.
I'm definately a beginner in robots, but i wouldnt pay that much for just a motor+chasis+battery, but then again i wouldnt know how much those would cost for robot of that size  :D
« Last Edit: February 23, 2007, 12:13:17 AM by SomeSaba »
Offline ed1380
« Reply #2 on: February 23, 2007, 01:25:15 AM »
I have been thinking about buying one at a yard sale, and salvaging the motors and batteries.
130? If I lose 5 punds I could ride in it..
« Reply #3 on: February 23, 2007, 12:32:51 PM »
soup up your power wheels for the Mini Grand Challenge:
http://www.cede.psu.edu/~avanzato/robots/contests/outdoor/index.htm
Last post November 15, 2008, 10:44:36 AM
by Tomas
Last post April 07, 2009, 11:57:49 PM
by datt
Last post October 12, 2009, 07:44:36 AM
by ddemarco5
Last post September 28, 2010, 09:16:25 PM
