Author Topic: Power supply  (Read 1740 times)
Offline Tomomastchi-projectTopic starter
Power supply
« on: January 06, 2009, 09:33:33 AM »
Hello,
I am currently working on a PIC project. I have a problem: I need to feed a 6V motor(through a motor control IC) from a 12V battery. I already tried to search "DC DC converter 12V 6V" on google, but it doesn't give any reasonable schematics which do not use 6V*1.5A=9W apart from the 9W the motors use. I do not want to throw away half the energy.
I think I should use something like a step-down converter. Would this http://www.elecfree.com/electronic/12v-to-5v-3a-dc-converter-step-down-regulator/ suit my needs?
Offline Geir
Re: Power supply
« Reply #1 on: January 06, 2009, 10:37:15 AM »
You could use a switching regulator, its more efficient then the liner ones. I used that on a project ones
« Last Edit: January 06, 2009, 10:44:50 AM by Geir »
$50 Robot schematic http://elektro.russemotto.com
Offline pomprocker
Re: Power supply
« Reply #2 on: January 06, 2009, 10:54:40 AM »
« Last Edit: January 06, 2009, 10:55:13 AM by pomprocker »
Offline Rebelgium
Re: Power supply
« Reply #3 on: January 06, 2009, 11:11:09 AM »
Hello,
the link you posted isn't a step down converter, it's a lineair converter and will waste half your energy.
the one from dimensionengineering is good.
orgcrime.net
Offline want2learn
Re: Power supply
« Reply #4 on: January 06, 2009, 12:02:27 PM »
try looking at the L4971 or L4963.
If memory serves they're 8pin dip and only cost about £3-4 each. They're fairly easy to use and a circuit for them is easily designed from the datasheet :)
Am I, or the others crazy?
Re: Power supply
« Reply #5 on: January 11, 2009, 06:57:58 AM »
Ok. I'll probably go for the L4971 switch regulator. In the datasheet it only shows an example of 3.3V...I need 6V or 5V. What do I need to change? How much current will I be able to draw when I use the L4971 to make 5V from 12V?
Re: Power supply
« Reply #6 on: January 11, 2009, 07:12:02 AM »
I'm sorry, I overlooked it. I will have to connect an external divider to pin 8.
I hope I can find the part here somewhere.
Thanks guys, I think I will be fine now.
Last post December 16, 2006, 09:28:49 PM
by Militoy
Last post January 10, 2009, 11:30:08 PM
Last post August 13, 2009, 10:47:09 AM
Last post June 23, 2011, 11:52:14 AM
