Author Topic: Modifying HS-475HB for continuous rotation problem  (Read 4044 times)
Offline StefanTopic starter
« on: January 06, 2009, 12:36:17 PM »
Hello,
I followed the tutorial about modifying servos for continuous rotation but when I finished the tutorial it seems the servo is not working correctly.  After adjusting the pot until the servo stopped spinning, I glued the pot in place by putting a drop of superglue on the pot. After letting it dry I plugged the servo in to check that it spins correctly and it just hums.  I have tried several different channels (i.e. center position sticks and free position sticks) on my transmitter.  I also checked the receiver battery voltage and it is fine.  The last thing I checked was to make sure none of the glue ran into the gear next to the pot and it did not.  It seems the motor just won't spin now that I have moved and glued the pot.  Any help would be appreciated.
My last idea to fix it is to use some superglue debonder to free the pot but I want to make sure that won't be harmful to the potentiometer.  I am sure any liquid dripping onto the circuit board would be bad.
Stefan
Re: Modifying HS-475HB for continuous rotation problem
« Reply #1 on: January 06, 2009, 01:06:42 PM »
« Reply #2 on: January 06, 2009, 01:21:22 PM »
I was hoping not to modify the electronics as this servo has the capability of decoupling from potentiometer by removing the gear insert.
« Reply #3 on: January 26, 2009, 04:07:29 AM »
Did you get it to work?
What program were you using to make the servo rotate (after modifying it)?
« Reply #4 on: January 26, 2009, 11:25:54 AM »
Yes I got it to work.  I ended up having a damaged gear so i replaced it.  Currently I am not using a program, I am just using a mix on my RC transmitter to get dual motor steering.  I am planning on purchasing a BotBoard soon to play with.
Last post April 06, 2008, 10:46:36 AM
Last post May 18, 2008, 12:32:43 PM
by airman00
Last post August 23, 2009, 08:32:07 AM
by Strikeskids
Last post May 30, 2009, 11:29:16 AM
by HarbingTarbl
