Author Topic: The ATmega328 an upgrade for the Arduino.  (Read 5694 times)
Offline Hawaii00000Topic starter
« on: January 07, 2009, 01:39:29 AM »
Would any of these work as a drop-in replacement for the ATmega128 in the arduino? http://www.stkcheck.com/evs/atmel/atmelheader2.asp?mfg=atmel&part=ATmega328P
-Paul Dirac
Its Hawaii Five-O. Get it?
Re: The ATmega328 an upgrade for the Arduino.
« Reply #1 on: January 09, 2009, 07:25:06 AM »
Yeap. You just need an ISP hardware programmer to upload a 328P compatible bootloader . . . not sure if Arduino supplies one yet or not . . .
Otherwise, you can use my 328P bootloader on my $50 robot page instead.
« Reply #2 on: January 10, 2009, 02:23:44 AM »
IS there a difference between them? What do the numbers at the end mean?
-Paul Dirac
« Reply #3 on: January 10, 2009, 02:37:07 AM »
Just look at the datasheets of each for comparison. They are pin compatible, just the later versions tend to be better like more memory and such.
The P at the end means its a low power version to save you ~15 mAh.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Offline pomprocker
  • Helpful? 111
« Reply #6 on: January 10, 2009, 06:46:23 PM »
Has anyone found an ATMega328 supplier in the UK yet?
Farnell, RS, Rapide etc don't seem to supply to it yet. Appreciate I could it buy it in from abroad but would need to buy loads of them to make it worthwhile.
Offline zooto68
« Reply #7 on: April 02, 2009, 05:27:37 AM »
I have them for sale. Email me if you are interested.
Offline sonictj
  • Helpful? 11
« Reply #8 on: April 02, 2009, 03:12:31 PM »
The standard arduino uses a ATmega168 20PU the drop in replacement is a ATmega328 20PU.  The bootloader is now part of the arduino software.  You can also use the bootloader from ladyada.  To burn the bootloader yourself you must have a hardware programmer.
