Author Topic: Mixing C and assembly  (Read 1658 times)
Offline dsPICgyTopic starter
« on: January 07, 2009, 06:22:11 AM »
Dear all,
I am confused with how project with mixed C and assembly is handled in Microchip C30. I have a very simple project that uses TMR1 interrupt to toggle an LED. I tried this project on dsPIC3312GP202 which is used in Microchip 16-bit 28-pin Starter kit.
I have a project that contains two files, one coded with C language and the other one coded in assembly. The C listing is as follows (main.c)
#include "P33FJ12GP202.h"
 * Internal FRC Oscillator
_FOSCSEL(FNOSC_FRC);
 * Clock switching is enabled and fail-safe clock monitor is disabled
 * OSC2 pin function: OSC2 is clock output
 * Primary oscillator mode is disabled
_FOSC(FCKSM_CSECMD & OSCIOFNC_OFF  & POSCMD_NONE);
 * Watchdog timer is disabled
_FWDT(FWDTEN_OFF);
 * Function prototypes
void initialisePorts( void );
void initialiseTimer1( void );
void performClockSwitching( void );
 * Main program entry
int main( void ) {
     * Initialise clock-switching
    performClockSwitching();
     * Initialise port direction and value
    initialisePorts();
     * Initialise Timer1
    initialiseTimer1();
     * Loop here doing nothing - waiting for Timer1 interrupt to occur
    while (1) {
    return 0;
 * Initialise input and output ports
void initialisePorts( void ) {
     * At the moment we are only interested in port B, where
     *  o Pin 5  - incoming data
     *  o Pin 6  - re-timed data
     *  o Pin 10 - recovered clock
     *  o Pin 12 - LED4
     *  o Pin 13 - LED3
     *  o Pin 14 - LED2
     *  o Pin 15 - LED1
     * Note 0 - output, 1 - input
    TRISB = 0b0000101110111111;
     * Initial value of port B
    LATB = 0xF000;
 * Initialise Timer1
 * Interrupt Service Routine will be called when Timer1 overflows
void initialiseTimer1( void ) {
    TMR1 = 0x00;
    PR1  = 53;           /* timer preload value */
     * T1CON register
     *  bit | Value | Description
     *  15  |   1   | TON - enable Timer1
     *  14  |   0   | Reserved
     *  13  |   0   | TSIDL - Not stop in idle mode
     * 12-7 |000000 | Reserved
     *   6  |   0   | TSYNC - sync to ext. clock disabled
     *  5-4 |  00   | TCKPS - prescaler of 1:1
     *  3-2 |  00   | Reserved
     *   1  |   0   | TCS - Internal clock as source
     *   0  |   0   | Reserved
     T1CON = 0b1000000000000000;
      * Set Timer1 interrupt priority
     IPC0 &= 0x0FFF;
     IPC0 ^= 0x1000;
      * Clear Timer1 interrupt flag and enable Timer1
     IFS0bits.T1IF = 0;
     IEC0bits.T1IE = 1;
 * Perform clock switching
void performClockSwitching( void ) {
 OSCTUN = 0;     /* Tune FRC oscillator, if FRC is used */
     * Configure oscillator to operate the device at Fcy = 40Mhz
     * Fosc = Fin*M/(N1*N2)
     * Fcy = Fosc/2
     * Fosc = 7.37Mhz * 43/(2 * 2) = 80MHz for 7.37MHz input clock
 PLLFBD = 43;    /* M = 43 */
 CLKDIVbits.PLLPOST = 0;  /* N1 = 2 */
 CLKDIVbits.PLLPRE = 0;  /* N2 = 2 */
     * Disable Watch Dog Timer
 RCONbits.SWDTEN = 0;
     * Initiate clock switch to FRC with PLL
     * NOSC = 0b001
 __builtin_write_OSCCONH(0b001);
     * Start clock switching
 __builtin_write_OSCCONL(0b001);
     * Wait for clock switch to occur
 while (OSCCONbits.COSC != 0b001)
     * Wait for PLL to lock
 while(OSCCONbits.LOCK!=1) {};
The assembly listing (T1Interrupt.s) contains the ISR of TMR1. All it does is to clear TMR1 interrupt flag and toggle an LED. The listing is as follows
   .text
      .include "p33FJ12GP202.inc"
; T1Interrupt - ISR of Timer1
__T1Interrupt:
             bclr IFS0, #T1IF                   ; clear interrupt flag
             btg  PORTB, #15
             retfie                             ; Return from interrupt
             .end
I built the project and then programmed with using RealICE to my starter kit. Everytime when I ran this project, it would be halted almost immediately.
However, instead of coding TMR1 ISR in assembly, if I added the following code to main.c and remove T1Interrupt.s from the project, the project ran perfectly.
void __attribute__((__interrupt__)) __attribute__((no_auto_psv)) _T1Interrupt( void )
    LATB ^= 0x8000;
 /* reset Timer 1 interrupt flag */
  IFS0bits.T1IF = 0;
Any idea why?
I look forward to hearing your feedback.
dsPICgy
Offline cosminprund
  • Helpful? 8
Re: Mixing C and assembly
« Reply #1 on: January 07, 2009, 11:54:34 AM »
What are you confused about?
Any ideas about what?
You're confused about something in the code or about how the compiler manages to generate code from two distinct files, one in C and one in Assembler?
« Last Edit: January 07, 2009, 11:55:44 AM by cosminprund »
« Reply #2 on: January 07, 2009, 01:44:02 PM »
Thanks for your reply. I was confused on why two same programs did not behave in the same way. One written as a mix of C and assembly, and the other one C only.
Anyway I have figured out the answer. The assembly code requires a function declaration of the ISR, otherwise default ISR will be executed. This explains why the program halts as soon as it is run.
Last post April 06, 2008, 05:29:29 PM
by izua
Last post June 19, 2008, 04:35:46 PM
by benji
Last post July 27, 2008, 05:14:45 PM
by izua
Last post May 14, 2009, 01:35:44 PM
by LunchBox!
