Author Topic: servo torque  (Read 1295 times)
Offline crarmTopic starter
servo torque
« on: January 09, 2009, 06:46:01 PM »
I am making a robotic arm that will have a rototiller at the end. This will only go in the ground about 1 inch. Does anyone have any suggestions on what servo I should use.
Offline want2learn
Re: servo torque
« Reply #1 on: January 10, 2009, 02:18:48 AM »
For digging the ground I would suggest that a servo wont give you a long service life, I would suggest a motor with a metal geared gearbox. As an example i would find an old 12 volt cordless drill and rip it apart to get the motor and gearbox.
This probably wont give a great service life either but if you replace the brushes in the motor first I'd bet it'll last longer than a servo, probably provide more power(torque) too.
This would mean building a simple H-bridge but adding the costs up it'll be cheaper than a servo too.
Am I, or the others crazy?
Re: servo torque
« Reply #2 on: January 10, 2009, 10:27:16 AM »
What kind of motor would that be. Something I could buy cheaper than buying a new drill (dont have a old cordless drill). Or replace fairly easy if it does die.
Offline ArcMan
  • Mmmm... Plasma
Re: servo torque
« Reply #3 on: January 10, 2009, 02:11:19 PM »
You probably won't be able to get the kind of power you need any cheaper than a cordless drill.
You could check ebay for used cordless drills.
Last post July 08, 2009, 03:48:53 PM
by Canabots
Last post December 23, 2009, 02:22:18 PM
by SMSimon
Last post February 27, 2011, 08:13:37 AM
Last post July 07, 2011, 07:43:49 AM
by waltr
