Author Topic: constant of 12 volt  (Read 934 times)
Offline louisTopic starter
constant of 12 volt
« on: January 10, 2009, 10:34:46 PM »
hello
i got  power supply (input 120v ac 60 hz 12w and output is 12v dc 500 mA)  but when i measure it with multimeter it said 17 volts. how can i reduce to constant of 12 volt?
thank you for your help
Offline frodo
  • BOW DOWN TO MY MIGHTY STARE!!
Re: constant of 12 volt
« Reply #1 on: January 10, 2009, 11:51:19 PM »
look on websites like rapid electronics, maplins etc etc and look for a 12V voltage regulator.
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
Offline want2learn
« Reply #2 on: January 11, 2009, 12:20:32 AM »
I take it this is a wall adapter, Their voltage tends to drop quite a bit as you load them up.
Just do as Soerren says in you other post.
How much amps or  Milliamps does your relay pull when energised???
All of the other components in your circuit will work fine from about 3.5V to 18V, it's only the relay that needs a closer tolerance on your voltage
I haven't looked at your circuit since yesterday and I got a head like a sieve but you may find that a diode or two will be enough to drop the voltage to a level your relay will be happier with. You may not need them at all.
Am I, or the others crazy?
Offline pomprocker
« Reply #3 on: January 11, 2009, 01:56:41 AM »
sounds like an unregulated wall wart. what you need it a regulated wall wart.
If you want to regulate it there is a voltage regulator with a 5% accuracy.
http://www.radioshack.com/product/index.jsp?productId=2062600
Or if you want it almost exact get an adjustable regultor with a small potentiometer and some resistors
http://www.radioshack.com/product/index.jsp?productId=2062601
Last post July 06, 2008, 10:49:15 AM
by twintriode
Last post September 19, 2008, 10:34:58 PM
Last post September 29, 2009, 09:13:22 AM
Last post September 04, 2010, 11:42:30 AM
by madsci1016
