Author Topic: Quick AVR question  (Read 1860 times)
Offline TrickyNekroTopic starter
  • 1.6L Peugeot 307 tuner
Quick AVR question
« on: January 11, 2009, 05:35:42 AM »
Hello again...
If I connect a pin (I/O) of my ATMEGA8 at 13V via a 1MOhm
resistor will things go puff or I'm ok???
Thanks in Advance,
Lefteris, Greece
Cheers!
Offline dunk
Re: Quick AVR question
« Reply #1 on: January 11, 2009, 06:04:55 AM »
i don't know to be honest. you would need to check the datasheet for the AVR I/O pins maximum current sink and resistance and calculate the minimum value of resistor needed.
the correct way to do this is to use a voltage divider. far less complicated to work out but one more resister in the circuit.
« Reply #2 on: January 11, 2009, 07:39:28 AM »
It's in a place I really can't use a divider...
I want to witch a MOSFET... and if I place a resistor to ground it turns on... and that's not good...
I'm trying out the op amp buffer right now....
I'm hell confused over this circuit...
I'm trying to make a kill switch with a mosfet gate...
One switch power up the circuit until microcontroller starts and opens the mosfet gate....
Maybe I'm having a wrong approach...
Maybe..... Darn I think I figured out the way!!!
I know it's silly... But sometimes you just don't act right!!!
Thanks for the answer!!! And thanks for the inspiration that post gave me!!! really!!!
Best Regards, Lefteris
Greece
Cheers!
Offline dunk
« Reply #3 on: January 11, 2009, 11:40:07 AM »
ah. 2 suggestions:
1. get a MOSFET driver. there are special drivers for driving MOSFETs from TTL logic levels.
2. get a TTL triggered MOSFET. maybe this one: http://www.fairchildsemi.com/ds/RF/RFP30N06LE.pdf
« Reply #4 on: January 11, 2009, 05:26:35 PM »
I had problems cause I wanted exasperated grounds and that...
Really messy things....
Thanks a lot for the advice! It seems that the IRF540 fully responds to the TTL levels with no problems.
The gate input for high is somewhere near 4V - 5V to 20V if I'm right...
So 5V is of TTL level...
I can do the trick with a op amp if I have a so serious problem...
Thanks for the interest and replies!
Best Regards,
Lefteris, Greece :)
Cheers!
« Reply #5 on: January 14, 2009, 11:04:38 AM »
I don't quite understand your question, but the typical AVR will fry above 5.5V.
Offline pomprocker
« Reply #6 on: January 14, 2009, 11:20:18 AM »
maybe sharing a schematic would help
Last post December 15, 2011, 10:25:01 AM
by Mahmoud
Last post June 23, 2012, 08:16:59 AM
by Proctor
Last post December 04, 2012, 12:24:22 PM
by jwatte
Last post March 19, 2013, 03:30:29 PM
by Mastermime
