Squirrels have fuzzy tails.
hi ! im new to this forum and i have a questioni have salvaged four RS 385 PH motors from a car(specs. http://www.mabuchi-motor.co.jp/en_US/cat_files/rs_385ph.pdf). i need each of them to run providing the maximum torque they possibly can for repeated periods of 30 seconds or so. as far as i know in a permanent magnet d.c motor the torque is dependent upon the supply current only. Here the stall current is in the range of 3 amps .will i get a stall torque that is close to the specified stall torque if i run the motor using a 12v 3 amp AC to DC adapter?also will there be heating issues? if so how to overcome them?
Started by hazzer123 Electronics
Started by dsesmg Electronics
Started by srgalli Electronics
Started by 123laurens Electronics
