Author Topic: Servo modification (Futaba S3003)  (Read 2711 times)
Offline bootstrapTopic starter
« on: January 13, 2009, 04:27:50 AM »
I want to know after modifying a servo (as given here is societyofrobots) will it be that the servo will be direction as well as speed control with the PWM?Also will the servos come to a halt at particular PWM value (say at the PWM value at which the direction just reverses).This way I want the robot to move fast ,slow or stop or rotate clock wise or anti using differential drive with the modified servos.
Re: Servo modification (Futaba S3003)
« Reply #1 on: January 14, 2009, 11:19:52 AM »
There is no position control with a modified servo. A modified servo will not hold it's position if you stop the PWM.
If you need position control with a modified servo, there are encoder kits you can buy.
« Reply #2 on: January 16, 2009, 02:42:01 AM »
Did modify it as you told and was able to develop a GUI (for speed control)
Last post January 30, 2008, 02:37:13 PM
by ed1380
Last post August 15, 2010, 06:48:04 PM
by scottad73
Last post February 16, 2010, 05:52:27 PM
Last post January 11, 2011, 02:01:37 PM
