Author Topic: Need Underside View of X-Bee  (Read 968 times)
Offline airman00Topic starter
« on: January 13, 2009, 09:07:57 PM »
I am thinking of making my own long range RF link and just want to see how "complicated" a similar RF link , the X-Bee , is .
The only view I can see is from here :
I want to see the other side of it , just to get a look at how complex the circuitry is.
If someone has a schematic for the X-Bee that would be even better.
Re: Need Underside View of X-Bee
« Reply #1 on: January 13, 2009, 09:16:15 PM »
A side note :
I found a picture of a Parallax RF receiver
Looks very simple - seems as if the big black chip in the middle is doing all the hard work. So what I have to do is find a chip that supports my range and then build a simple circuit to support it? Is it as easy as finding the right transmitter/receiver chip?
Offline pomprocker
« Reply #2 on: January 13, 2009, 10:03:52 PM »
The underside of the XBee is just a big silver square, you can see part of it from the back. If you need the breakout look at datasheets, or at xbee adapters people have built
Offline ArcMan
  • Mmmm... Plasma
« Reply #3 on: January 14, 2009, 04:00:17 PM »
I'm curious...
What kind of range are you planning on achieving.  Some XBee models get 25 miles LOS with a high-gain antenna.  If you can better that, call Digi.  I'm sure they'll hire you.  If not, why not just buy an XBee.
« Last Edit: January 14, 2009, 04:01:45 PM by ArcMan »
« Reply #4 on: January 14, 2009, 04:13:58 PM »
I'm curious...
25 miles range is probably directional, my application needs omnidirectional.
Anyways I don't need an Xbee at all  I found my solution - http://www.societyofrobots.com/robotforum/index.php?topic=6301.msg49162#msg49162 . I don't want to buy an Xbee because this is for a manufactured product (Xbee is pretty expensive), so I would make my own PCBs.
Last post March 23, 2008, 12:37:01 PM
Last post October 05, 2008, 06:07:21 AM
by MaltiK
Last post July 06, 2011, 03:23:45 PM
by Robot Attack
