Author Topic: need 3.3V LDO volt reg SMD with reverse polarity protection  (Read 2752 times)
Offline AdminTopic starter
« on: January 15, 2009, 08:10:39 AM »
I'm having serious trouble finding a:
voltage regulator
surface mount
3.3V
200mA+
low voltage drop LDO
thermal shutdown
Anyone know of a part number they can point me to? Mouser/Digikey don't include reverse polarity in the search option and I've gone through tons of datasheets already . . .
Offline izua
Re: need 3.3V LDO volt reg SMD with reverse polarity protection
« Reply #1 on: January 15, 2009, 09:34:03 AM »
what about switching mode regulators? they don't do anything if you drain current out of the input (as far as i know and tested), are efficient and most have thermal shutdown.
lm2576 comes in both smt and th versions. the downside is that it needs a few parts around it, and only this combination assures the rev polarity protection.
« Last Edit: January 15, 2009, 09:36:34 AM by izua »
Offline fuzzyt
« Reply #2 on: January 15, 2009, 10:43:30 AM »
Not sure it covers reverse polarity protection, but everything else seems to be in order...
http://www.st.com/stonline/books/pdf/docs/2572.pdf
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #3 on: January 15, 2009, 12:04:59 PM »
I think Schottky diodes have a drop down voltage around 0V15 to 0V45....
That will do... unless you are so space and cost restricted.... :P
Cheers!
Offline want2learn
« Reply #4 on: January 15, 2009, 01:33:28 PM »
Have you looked at Micrel's website http://www.micrel.com/index.do
They have a regulator which probably suits your needs 'MIC5209-3.3YM' . As far as I can see it meets all of your needs and is available in a couple of different SMD packages. :)
As for where to buy, you can check the availability on their website.
The only place I looked was (the dreaded) Digikey. Their prices aren't that bad but I've got to agree with your comments about their nosey policy >:(
Sorry I don't know how to post those fancy links I see others using
Am I, or the others crazy?
« Reply #5 on: January 15, 2009, 11:46:02 PM »
thanks want2learn!!!
The MIC5209-3.3YS seems to be *exactly* what I was looking for.
futureelectronics.com appears to be selling them at $0.69 each.
Offline pomprocker
« Reply #6 on: January 16, 2009, 05:48:11 PM »
aww man I just came back to this post to tell you about Micrel too. Guess I'm too slow
Last post July 06, 2008, 10:49:15 AM
by twintriode
Last post October 25, 2008, 05:53:40 PM
by gamefreak
Last post January 17, 2009, 01:35:30 PM
by Webbot
Last post January 04, 2010, 01:41:34 AM
by FrenchyDude
