Author Topic: L298 Motor Driver  (Read 16425 times)
Offline reSpawnTopic starter
L298 Motor Driver
« on: January 15, 2009, 01:35:25 PM »
Hello,
I'm building an L298 Motor driver pcb, and I need your suggestions.
Here is the schematic I've come up after doing some reasearch using google and L298's datasheet.
What do you guys think? Will it work? What changes I should make?
I want to drive only one DC motor, that's why I've put the outputs in parallel.
Offline Canabots
  • Helpful? 6
Re: L298 Motor Driver
« Reply #1 on: January 15, 2009, 04:50:49 PM »
Try comparing your schematic to the one used by the Solarbotics Compact motor driver. They both use the same chip.
http://www.solarbotics.com/assets/schematics/solarbotics_-l298_schematic.pdf
I don't know if the pinouts are different from that IC package to the one your using, but I hope this helps   ;D
This schematic is also for a DUAL motor driver, so just imagine that the outputs are in parallel like on your circuit.
Canabots  :)
« Last Edit: January 15, 2009, 04:52:19 PM by Canabots »
www.saltech.wordpress.com
Offline paulstreats
  • Helpful? 20
« Reply #2 on: January 16, 2009, 09:31:03 AM »
If i remember there should be a circuit example in the datasheet for the l298
Just follow that
« Reply #3 on: January 16, 2009, 02:09:49 PM »
Yes, but I wanted someone to look over my schematic and tell me if I did something wrong or not.
Can you please check it out?
Offline paulstreats
  • Helpful? 20
« Reply #4 on: January 16, 2009, 02:18:19 PM »
the circuit looks fine. The only thing that i would suggest is to use a potentiometer in conjunction with a good transistors on the sense pins. You will be able to "tune" the outputs like this.
quite often you might notice 1 motor moves faster than the other for no reason (slight manufacturing differences and tolerances)If you have a seperate pot and transistor for each sense pin then you can slow the faster one down a little.
« Reply #5 on: January 16, 2009, 02:23:19 PM »
as you can see, I only have one output. Anyway, tunnings can be made in software :P
  • Helpful? 107
« Reply #6 on: January 17, 2009, 07:14:27 PM »
Check out my tutorial http://www.societyofrobots.com/member_tutorials/node/159 The larger DC motor controller board uses a L298
Last post January 31, 2008, 01:02:10 AM
by TrickyNekro
Last post April 27, 2010, 11:41:46 PM
by Jak24
Last post June 19, 2011, 04:24:54 PM
by tzankoff
Last post December 26, 2011, 10:00:45 PM
by SzeHan
