Author Topic: Mounting Wheels  (Read 3350 times)
Offline ArcManTopic starter
  • Mmmm... Plasma
Mounting Wheels
« on: January 15, 2009, 03:23:37 PM »
Does anyone have experience mounting these neoprene foam wheels to hubs?
http://www.lynxmotion.com/Product.aspx?productID=237&CategoryID=39
I also bought the recommended hubs.  Can this wheel be disassembled and then the hub screwed and nutted to just the inside piece or do I need to drill through the entire wheel?
Offline frodo
  • BOW DOWN TO MY MIGHTY STARE!!
Re: Mounting Wheels
« Reply #1 on: January 15, 2009, 03:30:57 PM »
can't you just superglue the hubs to the wheel centres?
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
  • Mmmm... Plasma
Re: Mounting Wheels
« Reply #2 on: January 15, 2009, 03:47:41 PM »
I don't want to go that way.
The hubs are aluminum.  Super glue (cyanoacrylate) does not form a reliable bond with metal.  Even if it did, that would eliminate any possibility of changing the wheels.
Thanks for the idea, though.
Offline pomprocker
Re: Mounting Wheels
« Reply #3 on: January 15, 2009, 04:17:38 PM »
The two halves can be pulled apart if need be
Re: Mounting Wheels
« Reply #4 on: January 27, 2009, 12:39:16 AM »
http://www.societyofrobots.com/mechanics_chassisconstruction.shtml#wheels
Scroll down a bit until you see a pic of the wheel. I just drilled two holes and screwed in my servo hub.
  • Mmmm... Plasma
Re: Mounting Wheels
« Reply #5 on: January 27, 2009, 12:40:40 PM »
Looks good as a servo mount.  Thanks, admin.
But I actually needed to mount it to a hub for a 6mm flatted shaft from a gearmotor.  Here's how I ended up doing it.  The Lynxmotion hub had a #4-40 threaded hole at the center and a #4-40 screw for bolting it on through the center of the wheel.  The problem is that the wheel hole size is a #8, not a #4.  Tssk, tssk.  Very sloppy, Lynxmotion.  So I bored and threaded the hub for #8-32.  The wheel fit very tightly on the #8-32 screw and was nicely centered.  I used a star washer on the outside and some threadlock to make sure the screw didn't back out.  Bootiful.
Last post October 27, 2007, 03:06:02 PM
by stopgo
Last post July 18, 2010, 04:42:46 PM
Last post September 16, 2010, 03:02:12 AM
by Alfa_Zulu
Last post October 24, 2011, 03:58:02 PM
