Author Topic: Another Power Question  (Read 980 times)
Offline DanscoTopic starter
« on: January 16, 2009, 01:23:54 PM »
Hi All,
I'm sorry if this has been answered already. I tried searching but I need a brain check!
problem:
I have 12v battery, I have 12v motors (wheelchair) and I have a OOPIC-r micro.  The micro needs 5v regulated input.  (it has its own 9v to 5v regulator on it, but allows external regulated supply)    How to I get regulated 5v into my micro without letting out the magic smoke?   This widget (http://www.superdroidrobots.com/shop/item.asp?itemid=508) looks perfect.   Your comments please.
Thanks in advance.
Dansco
Re: Another Power Question
« Reply #1 on: January 17, 2009, 03:58:43 AM »
Why not build it yourself?
The regulator you linked to might work, but personally I have little faith in it, since the photo of the board is so blurred that you cannot make out which regulator IC they used. A pro company would not use such blurred photos.
Further, from their choice in components, it seems they are not too good at regulator design.
Offline want2learn
« Reply #2 on: January 17, 2009, 05:44:15 AM »
I've got to agree with Soeren again :D
They're going to charge the better part of $10 for that :o. Then an additional charge for the heatsink!!! >:(
I've never looked for PSU's before but that seems like a rip off to me.
What regulator's on the board you've got, maybe it can be swapped out without too much hassle.
I'm not familiar with your board so I can't say more for now.
Am I, or the others crazy?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #3 on: January 17, 2009, 07:46:20 AM »
I have powered my OOPic-R board directly from a 12V SLA battery whith no regulator heating. That is because the board draws little current. However, I was using a 6V regulator for the servos that was heating up a lot so I had to power the servos directly from a 6V SLA battery.
Last post October 30, 2007, 01:57:40 AM
by stopgo
Last post December 28, 2008, 03:04:48 AM
Last post August 30, 2009, 08:14:41 PM
by emoseman
Last post October 14, 2009, 05:59:25 PM
by galannthegreat
