Author Topic: Futaba S148 servo modification - plz help  (Read 2455 times)
Offline frodoTopic starter
  • BOW DOWN TO MY MIGHTY STARE!!
« on: January 17, 2009, 07:23:00 PM »
hi, has anyone used the Futaba S148 servo? if anyone has, is it the same to modify as the hitec HS-311 using admins instructions?
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
Re: Futaba S148 servo modification - plz help
« Reply #1 on: January 17, 2009, 07:47:16 PM »
All servos run on the same principle, so you will be able to modify it without a problem.
« Reply #2 on: January 18, 2009, 07:37:32 AM »
ok thanks.
Check out my Web
« Reply #3 on: February 02, 2009, 07:42:20 AM »
Some of the really small micro servos aren't modifiable, at least not easily. Standard size servos are all modifiable.
Offline scottad73
« Reply #4 on: August 15, 2010, 06:48:04 PM »
just for those interested, the Hitec HS322-HD is one of the easiest servos to mod to 360 degrees.  Just center the servo, remove the gear case, cut the notch on the drive gear, cut the exposed knob off from the pot and glue the cut knob. your done.  web has good pics of it
