Author Topic: Soldering Question  (Read 4553 times)
Offline Joesavage1Topic starter
Soldering Question
« on: January 18, 2009, 07:05:55 AM »
can a soldering iron (or gun in my case) be too hot? because when i used to randomly unsolder things, like old TV remotes, my old flytech dragonfly; some of the components burned out and broke, I've already bought new solder (22 gauge) to make sure i dont brake the components but will i need a new soldering iron/gun??
Thanx
Joe
EDIT: i Have an old Weller Universal soldering gun of some kind.
« Last Edit: January 18, 2009, 07:27:54 AM by Joesavage1 »
Re: Soldering Question
« Reply #1 on: January 18, 2009, 07:17:56 AM »
too hot is relative. Some components can only handle a small amount of heat, anything higher and they will burn out. Other components can handle a lot of heat.
« Reply #2 on: January 18, 2009, 07:26:06 AM »
Thanks for the reply, what do you suggest i do?
« Last Edit: January 18, 2009, 07:28:32 AM by Joesavage1 »
Offline HDL_CinC_Dragon
« Reply #3 on: January 18, 2009, 08:17:31 AM »
Try your hardest to solder as far away from the component as possible and try to make sure your iron isnt on it any longer than absolutely necessary. There are also little heat sink clips you can buy such as one from RadioShack for 2 bucks.
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Offline want2learn
« Reply #4 on: January 18, 2009, 11:23:25 AM »
The soldering Gun you're using is a pistol grip type isn't it ;)
These are far too hot for about 60-80% of electronic components.
You need to buy an iron, those pistol grip soldering guns are meant  for heavy duty soldering. Heavy gauge wires and some chassis mount connectors require this type of gun as they act as heatsinks and draw heat quickly away from the connection whereas pcb work doesn't.
If you have the money (£20 is ok) buy yourself a 18/24 watt soldering iron with a very fine tip, almost like a pencil or needle.
While you're at it buy a cheap stand with a small sponge holder.
If I'm wrong then sorry but your technique needs a lot of work
Am I, or the others crazy?
« Reply #5 on: January 18, 2009, 11:25:00 AM »
yes it is a pistol type grip, ill see if i can buy a new iron, but thanks for the heat clip suggestion anyway HDL_CinC_Dragon =D
« Last Edit: January 18, 2009, 11:28:13 AM by Joesavage1 »
« Reply #6 on: January 18, 2009, 11:47:16 AM »
Does anyone know were i can get a decent soldering iron (one that dosn't fry components) in the UK?
I can spend up to like £30 although cheaper is better, (i still want 1 that lasts a while though)
Joe
Offline frodo
  • BOW DOWN TO MY MIGHTY STARE!!
« Reply #7 on: January 18, 2009, 11:50:17 AM »
maplins ones are crap, they last about a day. thats the lesson i learnt.
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
Offline Gertlex
  • Helpful? 23
« Reply #9 on: January 18, 2009, 12:30:12 PM »
is this soldering iron ok?
http://www.rapidonline.com/Tools-Fasteners-Production-Equipment/Soldering-Equipment/Soldering-Irons/High-efficiency-25W-soldering-iron-with-fitted-mains-plug/60704/kw/85-0660
Joe
That looks like it'd work.  I couldn't find what temperature it operates at, though... (but I'd say 99% chance it's more than enough).
But ya... find the temperature out.  I got a new soldering iron for xmas... 900ºF.  I haven't used it yet.... because as far as I understand, that's a very high temperature for soldering.  I should have bought the new soldering iron myself x_x.
Also, I'd go for one that comes with a stand... just out of preference.
I
« Reply #10 on: January 18, 2009, 12:33:37 PM »
ok, ill take you up on the fact it will work =D, im buying it now
Joe
Offline want2learn
« Reply #11 on: January 19, 2009, 12:35:48 AM »
The Iron will be fine, remember to order the stand at the same time though.
Not a lot of soldering irons for sale in the U.K. actually show operating temperature. 25W is ok for through hole component work.
« Reply #12 on: January 19, 2009, 12:40:20 PM »
would this stand fit it?
http://www.rapidonline.com/Tools-Fasteners-Production-Equipment/Soldering-Equipment/Iron-Stands/Soldering-iron-stands-and-sponges/30437
If not can you find me one that would on Rapidonline.com?
Joe
« Last Edit: January 19, 2009, 12:41:56 PM by Joesavage1 »
Offline frodo
« Reply #13 on: January 19, 2009, 01:14:11 PM »
no that stand would not fit because that stand is for weller soldering irons, not xytronic soldering irons.
Check out my Web
« Reply #14 on: January 19, 2009, 01:15:09 PM »
can u find me one on Rapidonline that will fit??
Joe
Offline paulstreats
  • Helpful? 20
« Reply #15 on: January 19, 2009, 01:15:27 PM »
Not sure how much you want to spend, but i noticed this a few months ago:
http://uk.farnell.com/duratool/d00675/soldering-station-uk-plug/dp/149836449
Its a temperature controlled "soldering station" for about £30.
« Reply #16 on: January 19, 2009, 01:30:31 PM »
Ive found out the stand i was going to buy wouldnt fit, so im going to twist an old coathanger into a shape and get a small spounge for the cleaning spounge, Many thanks to Frodo for the Idea.
Thank you all for your greatly needed help.  ;D
Joe
  • Helpful? 107
« Reply #17 on: January 19, 2009, 02:10:13 PM »
Sorry - but IMHO some folk are trying to make this seem more complex than it is.
Soldering irons don't fry anything - it's how you use them. I've got several Weller, and Antex, irons - all cheap - which have lasted me for years (the Weller since 1970s). None have soldering stations - they are just 'hot metal'. OK - I don't spend ages de-soldering things and, if I do, I  use a solder braid. But so far, and touch wood, I haven't managed to fry anything. But at the end of the day you get what you pay for.
@Frodo -
maplins ones are crap, they last about a day. thats the lesson i learned.
From previous off line chats you said these were like 'own brand' and cost about £3 (say $5) each. £3 is too good to be true. But they sell Antex irons as well - and, as already said, they do the job for me. Not brilliant - but completely functional for the average person like me.
@Joesavage1 - a stand is just somewhere to plonk something hot. So most stands are just a coiled wire - to dissipate heat. So Frodos 'bent coathanger' will work. But most stands will work as the diameter of irons are pretty similar. Again - my 'one and only' iron stand is from the 1970s - no idea WHAT iron make it was intended for but works with all of the irons Ive got.
Temperature - guns etc. I believe guns are somewhat 'high temperature shotguns'. Use your soldering iron + braid.
There's no way I'm going to spend a fortune on a sophisticated iron. So even if I do fry a few AtMegas (haven't done it yet) then its a fraction of the cost of a professional iron.
Lets be pragmatic. I'd rather spend the money I save on electronics.
Offline frodo
« Reply #18 on: January 19, 2009, 02:18:03 PM »
@ Webbot -
ye £3 is a good price and all i was able to afford at  the time but i intend on getting one now that might last longer than 1-2 days.
Check out my Web
Offline want2learn
« Reply #19 on: January 19, 2009, 02:36:25 PM »
I wasn't trying to make this complicated at all. Those pistol grip soldering irons are not intended for PCB work, they are used in applications where heat draw is a problem e.g. heavy duty wiring some connectors, hell I even used one to solder the copper pipe in a homebrew solar water heater.
A beginner would find it most difficult to use one of these for PCB work, especially on a crowded board.
If you weren't referring to me then you have my sincerest apologies, I've had a terrible day.
BTW My first soldering iron was the cheapest that you could get (1.50ish). It lasted more than 4 years before I burned it out. As long as you turn them off when you wont be using them they'll definitely give you your money's worth
« Reply #20 on: January 20, 2009, 12:57:25 AM »
Thanks for all your advice everyone,
As i have said THANKS A BILLION, im going to go with the coathanger =D, oh and while im here im just going to take this off subject, are these ok for my $50 they were not the UK code on paula's list cause they were out of stock:
its number 22-0185 on
http://www.rapidonline.com/Cables-Connectors/Connectors-Multipole/DIL-Sockets/Low-profile-DIL-IC-sockets/63772/kw/22-0175
Thanks, and sorry for this unrelated question, just though i may aswell make use of this thread. =D
Joe
  • Helpful? 107
« Reply #21 on: January 20, 2009, 05:51:42 AM »
No - you can't use that one because it is 0.6 inches wide rather than 0.3 inches wide.
« Reply #22 on: January 20, 2009, 01:14:11 PM »
is there a way that i can use this in it, as ive already ordered?   :'(
Offline frodo
« Reply #23 on: January 20, 2009, 01:26:26 PM »
you could solder single strand wire onto the pins of the microcontroller then shove the wires into the corresponding bits in the socket but its fiddly.   :-\
Check out my Web
Offline cosminprund
  • Helpful? 8
« Reply #24 on: January 21, 2009, 06:25:24 AM »
Cut off the plastic tabs in the middle so the sides can get closer to each other. Or just go to an local shop and get a new one that's the correct size and keep this one for later.
« Reply #25 on: January 21, 2009, 11:21:33 AM »
can you draw me a diagram, which plastic tabs?
Offline frodo
« Reply #26 on: January 21, 2009, 11:31:34 AM »
the tabs in the middle of the socket that join the two sides together.
Check out my Web
« Reply #27 on: January 24, 2009, 10:32:12 AM »
I rung them up, and ordered a pack of 15 as they were the only ones they had in stock =D
Joe
« Reply #28 on: January 27, 2009, 11:55:51 AM »
Haha, we had electronics today at school and it turns out that the school use Rapid as an electronics company they get there stuff from; this whole time ive been using the soldering iron at school that im getting at home! turns out they have a education site too; http://www.rapidonline.com/Educational-Products , Hope this link comes in use to someone; =D
Joe
Offline frodo
« Reply #29 on: January 27, 2009, 12:43:05 PM »
 :D our school also uses Rapid Online for technology stuff and science! i've even thought about asking them to put stuff on the mailing list for me and i'd pay them how much it costs but i've never got round to it lol. good luck with your robot, Joe.
Check out my Web
Last post July 17, 2007, 06:55:58 PM
Last post January 30, 2009, 03:42:08 PM
by HDL_CinC_Dragon
Last post July 15, 2009, 03:44:50 AM
by mdmedlin
Last post November 29, 2009, 07:10:56 PM
