Author Topic: Axon not connecting  (Read 2180 times)
Offline robotcoderTopic starter
Axon not connecting
« on: January 20, 2009, 11:02:45 PM »
I recieved my Axon in the mail this Monday and began the Axon tutorial.  I was able to successfully go thru all of the steps, until I attempted to connect the Axon using the hyperterminal.  I checked the baud rates and they are all set to 115200.  I went a head and tried the bootloader and I am not able to install any code using it, it just spins |.  I also have a programmer, the AVRISP that I attempted to install with, but it gave me an Error saying Connect failed when I tried to connect.  If anyone has any ideas on what is going on, it would help.  It seems like the connection between the Axon and the computer isn't working even though the drivers seemed to install correctly.
Thanks, RobotCoder
Offline yerbie
Re: Axon not connecting
« Reply #1 on: January 21, 2009, 07:49:46 AM »
it's suppose to do that.  Then you need to turn on the battery to give it power so that it can program it.  Seems like you didnt do step 4.
Did you follow these instructions? http://www.societyofrobots.com/axon/axon_getting_started_bootloader.shtml
Press enter, and now you will see a \ symbol spinning.
STEP 4: Turn On Axon
Turn on your Axon, and it should now upload your .hex file.
Remember, the bootloader must always be activated BEFORE you turn on the Axon or it will not work.
« Last Edit: January 21, 2009, 07:52:25 AM by yerbie »
« Reply #2 on: January 21, 2009, 08:48:08 AM »
When I turn the battery on nothing happens, it just keeps spinning and never connects.
« Reply #3 on: January 21, 2009, 08:54:20 AM »
The fact that the ISP programmer *and* the bootloader aren't working make me suspect the battery voltage is too low. Check it with a multimeter, both before and after you turn the Axon on.
« Reply #4 on: January 31, 2009, 01:47:09 PM »
It was the battery, got a new battery and charged it properly.  Works Great now.
Last post November 18, 2008, 09:50:02 AM
by mbateman
Last post January 15, 2009, 09:15:48 AM
Last post January 10, 2009, 07:38:30 AM
by Tomas
Last post June 09, 2009, 06:26:31 PM
