Author Topic: tsop sensor  (Read 7740 times)
Offline karmaxTopic starter
tsop sensor
« on: January 24, 2009, 12:02:46 PM »
i am using tsop sensor by this circuit but output is always 4 tp 5 v.can any body tell me wht should be the output
« Last Edit: January 24, 2009, 12:04:11 PM by karmax »
Re: tsop sensor
« Reply #1 on: January 24, 2009, 12:44:22 PM »
[...] output is always 4 tp 5 v.can any body tell me wht should be the output
Does the LED light when modulated light hits the sensor? Output should be low when it does.
A 4k7 resistor for R3 might help.
As a first test, put the front of your TV-remote a short distance (like a few inches) from the TSOP (the side with the round mould) and press eg. Vol Up (as it is a repeating key). That should get your output down.
Offline izua
Re: tsop sensor
« Reply #2 on: January 24, 2009, 04:49:19 PM »
It's normal for the output to be high, TSOP sensors work in negative logic (1 is off, 0 is on).
Last post November 01, 2007, 12:46:48 PM
by evilknight007
Last post March 26, 2008, 03:06:36 PM
by AndrewM
Last post May 06, 2008, 01:59:18 PM
by TrickyNekro
Last post March 16, 2009, 05:23:33 PM
by radu19880625
