Author Topic: MKII Programmer Question?  (Read 1510 times)
Offline yankeefan238Topic starter
« on: January 25, 2009, 07:56:47 PM »
After reading this tutorial: http://www.societyofrobots.com/member_tutorials/node/290 I now have a question about the mkII programmer. In the tutorial it says that you can use the MKII for your 50$ robot only if you get an adapter. If i am going to be using the atmega 328p will i need this adapter? The problem is that the program header is still the same and I don't think the pins fit the MKII programmer without the adapter. Does anyone know if I really need this?!
Re: MKII Programmer Question?
« Reply #1 on: January 25, 2009, 09:01:36 PM »
No need.
Offline pomprocker
« Reply #2 on: January 25, 2009, 09:48:20 PM »
In the original $50 robot schematic, it calls for you to solder on a 2x5 header. The MKII can only handle a 2x3 header. The serial 'bit-bang' programmer fits the 2x5 header. You can either chose to solder on the 2x3 header onto your board instead of the 2x5 header, or you can buy or make an adapter
« Reply #3 on: January 26, 2009, 04:35:40 PM »
Ok, so I will just solder a 2x3 pin header instead. Thanks! :)
Last post February 13, 2008, 07:20:36 PM
by garriwilson
Last post March 09, 2009, 01:53:04 PM
by Weee
Last post June 23, 2012, 10:58:33 AM
by Proctor
Last post January 25, 2011, 12:05:29 AM
by walkercreations
