Author Topic: Help with PWM on ATMega168!  (Read 2320 times)
Offline cloneTopic starter
« on: January 27, 2009, 10:07:10 AM »
OK so I'm using the arduino board with atmega168, and i basically just want to adjust the speed of a DC motor using a potentiometer and PWM.
How do i do this???!!
thanks
Offline yerbie
Re: Help with PWM on ATMega168!
« Reply #1 on: January 27, 2009, 11:39:37 AM »
Member Tutorials:
PWM on ATmega168: http://www.societyofrobots.com/member_tutorials/node/226
PWM Overview: http://www.societyofrobots.com/member_tutorials/node/228
Not sure how you would do it using a pot, but you can adjust the speed with just pwm
« Last Edit: January 27, 2009, 11:41:35 AM by yerbie »
  • Helpful? 107
« Reply #2 on: January 28, 2009, 03:09:06 PM »
Connect the pot to an ADC to give you a value from 0 to 255 and then use this to adjust the duty cycle of the PWM.
« Reply #3 on: January 29, 2009, 10:32:04 PM »
im under the understanding that you cant have a DC motor hooked up directly to the arduino or it will have disasterous affects.. and also i watn to run the DC motor at 12 volts.. so what should i use as a 'motor driver'??
  • Helpful? 107
« Reply #4 on: January 29, 2009, 10:50:20 PM »
You need to find the maximum (stall) current for your motor and then find a motor controller that can supply it. Hard to recommend any driver without knowing the current requirement.
Last post June 03, 2010, 09:41:13 PM
by javila
Last post June 03, 2010, 02:45:54 PM
by amando96
Last post November 14, 2011, 01:59:02 PM
Last post November 20, 2011, 02:03:04 PM
by farnoise
