Author Topic: What is the best general sensor?  (Read 1650 times)
Offline galannthegreatTopic starter
« on: January 27, 2009, 10:17:13 PM »
I need help in deciding what type of sensor to choose and how i should use it on, basically, my first robot project.
Kurt
Re: What is the best general sensor?
« Reply #1 on: January 27, 2009, 10:52:48 PM »
That cannot be answered without knowing what you want to sense!
(A humidity sensor is no good if you want to sense color)
« Reply #2 on: January 27, 2009, 11:04:22 PM »
ah good point, sorry. Just generally speaking an object sensor for object avoidance.
Kurt
« Reply #3 on: January 28, 2009, 05:37:28 AM »
Sharp IR is the best object avoidance sensor for a beginner.
« Reply #4 on: January 28, 2009, 10:53:02 AM »
I usually see that sensor with a servo attached to it, how would I do that with a PIC 16F877a? I know how the sensor hooks up but how would i get the servo to scan back and forth?
Kurt
« Reply #5 on: January 28, 2009, 11:05:08 AM »
« Reply #6 on: January 28, 2009, 11:07:30 AM »
thank you very much :)
Kurt
« Reply #7 on: January 28, 2009, 11:48:48 AM »
on another note, how would i connect the servo to the MCU?
Kurt
« Reply #8 on: January 28, 2009, 12:01:33 PM »
I believe you need to search before asking :P
(read the servo tutorial)
« Reply #9 on: January 28, 2009, 05:03:58 PM »
now, in your own expierience did it help to pull the signal of the servo high or low by default? and should i do the same with the sharp module or is there one built in?
Kurt
« Reply #10 on: January 28, 2009, 10:47:14 PM »
can someone help me out with this i plainly need to connect these things to my PIC MCU on my own homemade board.
thanks
Kurt
Offline paulstreats
« Reply #11 on: January 29, 2009, 11:07:10 AM »
Neither the servo nor the sharp ir need pulling low by default. If you use a servo correctly then the signal wire is constantly being altered. The sharp ir signal wire is an output wire so you shouldnt be controlling it at all, it just contains a varying voltage.
Do you mean how do you physically connect them ? if so then well need to see a picture of youre board
or do you mean where to connect them on the PIC? this depends on which port you want them on. The sharp ir signal wire wants to connect to the portA0 pin most likely (being the first analog pin). The servo signal wire wants to connect to a general i/o port like portD0.
« Reply #12 on: January 29, 2009, 12:06:07 PM »
Thank you, that is exactly what i wanted to know. I just needed the bits to connect them too.
Kurt
Last post November 10, 2007, 08:55:54 PM
Last post March 31, 2009, 03:54:14 PM
by superchiku
Last post August 07, 2009, 02:37:53 PM
by Webbot
Last post November 30, 2009, 09:18:09 AM
by Vepar
