Author Topic: Another soldering question...  (Read 1136 times)
Offline yankeefan238Topic starter
« on: January 29, 2009, 04:48:31 PM »
I have solder that has a diameter of 0.050 is this to thick for soldering the 50$ dollar robot? What diameter of solder do I need. Also, my soldering iron can either be set at 15W or 30W And I don't know if 30 is too hot for lead solder and my components but 15W seems too little. Any advice?
Re: Another soldering question...
« Reply #1 on: January 29, 2009, 05:23:42 PM »
30w is perfect, and your solder is fine too. Don't worry about your components, they can handle more heat than you can imagaine (as long as you dont solder with the microcontroller in the socket). Just don't stick your iron on the parts for 20 seconds.
Offline Joesavage1
« Reply #2 on: January 30, 2009, 01:13:27 AM »
well mine is 25 (volt of watt i forget) and it melts 22 gauge perfectly, 22 gauge is the avarage and it will probably work on most soldering irons =D
Joe
Offline HDL_CinC_Dragon
« Reply #3 on: January 30, 2009, 03:42:08 PM »
that would be Watts Joe :)
I use a 40W weller and my preferred solder is .032" diameter 60/40 rosin core for pretty much everything I solder :)
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Last post July 17, 2007, 06:55:58 PM
Soldering Question
Started by Joesavage1 « 1 2 » Misc
Last post February 09, 2009, 10:32:58 PM
Last post July 15, 2009, 03:44:50 AM
by mdmedlin
Last post November 29, 2009, 07:10:56 PM
