Author Topic: Any one identify this sensor  (Read 1406 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
« on: February 04, 2009, 06:26:50 AM »
I bought this IR sensor yesterday from a shop. its number is "OS 0650" this is the only sensor type they had.top of the sensor is like a lens.I tried to find a data sheet for this but it seems "OS 0650" does not exist.
or is this sensor is known in some other name? if anyone identify this please help me to find a datasheet.
here are two pictures of it.
thanks
I'm Me
Offline TrickyNekro
  • Helpful? 15
  • 1.6L Peugeot 307 tuner
Re: Any one identify this sensor
« Reply #1 on: February 04, 2009, 07:31:51 AM »
I think that this is an IR led....
But it also maybe an IR sensor...
Try applying 3V with a resistor and see with a mobile camera if it's lit....
Cheers!
« Reply #2 on: February 04, 2009, 07:35:54 AM »
it is a IR sensor.what i need is to find a data sheet
I'm Me
Offline TrickyNekro
  • Helpful? 15
« Reply #3 on: February 04, 2009, 07:42:02 AM »
EEggrr... you don't need a datasheet... use it as a simple photo transistor....
Cheers!
« Reply #4 on: February 04, 2009, 07:44:31 AM »
no i need to find how sensitive is it and what are range of IR it can be use with
thanks
I'm Me
Offline TrickyNekro
  • Helpful? 15
« Reply #5 on: February 04, 2009, 07:57:42 AM »
It's an IR photodiode... the more IR the bigger the reading you get... aka it's an analog sensor....
These are affected by sun light so be careful with that...
They are the cheapest sensors to use.... and they are nice for making a Line follower...
That's all....
You need to invest some time into it... to make it have trust worthy readings....
Best regards,
Lefteris, Greece
Cheers!
Offline frodo
  • BOW DOWN TO MY MIGHTY STARE!!
« Reply #6 on: February 04, 2009, 11:58:42 AM »
what was the point of asking what it is if you already knew, aruna1?
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
« Reply #7 on: February 04, 2009, 03:03:25 PM »
Hi Lefteris,
IR is not just IR, and important things like the peak wave length, angle of half intensity etc. can be quite important match to succeed.
Aruna <- Doesn't it contain any other writing/marking than "OS 0650"?
« Reply #8 on: February 04, 2009, 04:38:42 PM »
nope,no other writings just"OS 0650"
I'm Me
« Reply #9 on: February 15, 2009, 04:45:27 AM »
Hook up a multimeter to it on the resistance setting, and see what happens depending on the amount of sunlight applied to it.
Last post December 10, 2008, 06:24:07 PM
by fuzzyt
Last post January 10, 2009, 02:00:25 AM
by want2learn
Last post June 11, 2009, 01:14:10 PM
by GearMotion
Last post March 09, 2010, 06:57:48 AM
by robaker
