Author Topic: IR Detector - Understanding multimeter results  (Read 1434 times)
Offline oliverj4455Topic starter
« on: February 06, 2009, 03:29:24 AM »
Hi there everyone,
I am trying to make some IR sensors (http://www.societyofrobots.com/schematics_infraredemitdet.shtml) but first I need to test the resistance of my IR detector. So I plug it into a multimeter and on all settings I get a 1 returned on the screen i.e. infinite resistance (relative). My multimeter goes up to 2M Ohms. When I shine an IR LED onto the detector the multimeter (still in 2M Ohms setting) jumps down to -0.550 Ohms. Then I move the LED away slowly and the multimeter reading gets closer to zero, continue moving it away and it quickly rises through th positive numbers up to a value of nearly 2. I connected the leads from the multimeter the other way around and just get a continuous reading of 1.
Can anyone help me make sense of this reading ro perhaps suggest a resistor value that I should use?
Thanks,
Oliver
Re: IR Detector - Understanding multimeter results
« Reply #1 on: February 06, 2009, 05:24:03 PM »
The phototransistor is working in photovoltaic mode, hence the negative reading when you shine a light on it.
A suggested value is allready in the text (10k), but if you just wanna discriminate between absolute dark and light, anything between a few kOhm to a few MOhm should be useable.
Last post January 29, 2007, 10:28:57 AM
by Steve Joblin
Last post September 15, 2007, 04:20:34 PM
by paulstreats
Last post October 11, 2010, 06:44:30 PM
Last post April 01, 2011, 05:18:41 PM
