Beginners: please read this post and this post before posting to the forum.
wicked. at least you've built a robot
is at as good as contact adhesive or super glue, or does it just depend on the material its used on?
Hi,Quote from: Joesavage1 on February 08, 2009, 08:12:41 AMis at as good as contact adhesive or super glue, or does it just depend on the material its used on?Bonding technology is a hugely wide subject.Contact glue is not a single product, but sort of a family, where some are good for some materials and then again some for other materials. For leather work eg., I only go with a product called Neotol, which for leather is several times stronger than "ordinary" contact glue.Super Glue (Cyanoacrylate) has evolved to a family as well and some types can even be had with different hardening times. Cyano goes with almost anything, a gelled type is used for porous materials. It is used in forensics as well, to "develop" fingerprints with, by putting the object with finger prints in a closed aquarium with a flat dish with liquid glue in it - after a while, the prints can be seen in white, as the cyano hardens on the grease of the prints.Epoxy is very strong and adheres to most materials (some plastics is a problem for most glues) and differs itself from cyano by its non sinking property - it can fill out missing parts, whereas the cyano needs totally fitting parts.Like a single screwdriver won't fit all screws, no single glue will fit all bonding jobs.
this is the schematic which shows you where the stuff goes
Started by NGuggemos Mechanics and Construction
