Author Topic: PWM axon source code  (Read 3011 times)
Offline Its_FridayTopic starter
« on: February 08, 2009, 12:31:58 PM »
I am trying to figure out PWM for servos but i haven't been able to find example code for the axon microcontroller. All i have found are .hex files for centering servos, and i can't read .hex xD
  • Helpful? 107
Re: PWM axon source code
« Reply #2 on: February 08, 2009, 01:06:41 PM »
I have already read that and understand the under lying principles of PWM but i don't know how to code PWM for servos.
  • Helpful? 107
« Reply #3 on: February 08, 2009, 01:16:52 PM »
This section talks specifically about servos and PWM http://www.societyofrobots.com/member_tutorials/node/231
It includes code for a 1MHz ATMega8
So if you are using a 16MHz Axon then follow the example as it explains what varies according to the CPU frequency.
The reference section shows tables for the ATMega8, 168, and Axon. So you can translate each of the register names from the example into the equivalent registers for the Axon.
« Reply #4 on: February 08, 2009, 01:29:05 PM »
i'm interested in simple source code which uses the axon source code functions. I'm a novice at programming and am unfamiliar with registers. :-[
Offline mbateman
« Reply #5 on: February 08, 2009, 03:06:47 PM »
« Reply #6 on: February 09, 2009, 04:07:39 PM »
« Reply #7 on: February 09, 2009, 09:17:11 PM »
Last post January 11, 2009, 06:57:51 AM
Last post February 13, 2009, 09:26:22 PM
Last post March 05, 2009, 07:49:24 PM
by LIONS*LEADER
Last post August 21, 2009, 07:04:28 PM
by PhilG
