Author Topic: Automatic Turret  (Read 14613 times)
Offline Razor ConceptsTopic starter
  • Helpful? 53
Automatic Turret
« on: February 08, 2009, 06:16:18 PM »
Dot matrix business card is basically done so next project... automated airsoft turret.
Currently I have modifed a cheap AEG to be triggered by a relay, and the relay is triggered by the microcontroller.
AEG was modifed by opening it up, removing unnecessary components, and using gardening shears to cut off excess plastic. A dremel took care of touching it up to look cleaner. The motor is hooked up directly to the relay.
Simple relay board, I decided to make it on protoboard just in case I fried the relay (first time working with them). Some connectors and one diode was all that was needed.
For asthetics, I would be making a laser "eye" like in the portal turrets. A hole is drilled in the center to accomodate a laser. I masked off parts around it that will light up red/green.
Offline cooldog
Re: Automatic Turret
« Reply #1 on: February 08, 2009, 07:33:00 PM »
next you could mount it on servos
then you could use the stampy robot code moded so that it will follow the target
-admin
favorite web sites
http://www.societyofrobots.com/
http://www.instructables.com/
Offline airman00
« Reply #2 on: February 08, 2009, 07:39:40 PM »
you need a MOSFET or transistor to drive the relay
Offline Metal Slug 2
  • Helpful? 11
« Reply #3 on: February 08, 2009, 10:44:47 PM »
Wow! That is So wickedly Awesome!!!
I am definelty gonna try and build one!!..or two...or three..(or one base with three turrets).........
« Last Edit: February 08, 2009, 10:53:37 PM by Metal Slug 2 »
  • Helpful? 53
« Reply #4 on: February 09, 2009, 03:41:13 PM »
After painting and removing masking
Light coat of paint over entire thing to diffuse light
Laser installed
Painted gun white (what is with the clearsoft guns)
Fill inside with cotton to diffuse light, wrap inside with electrical tape to prevent light from coming out the sides
Insert laser and leds
 :o
Offline frodo
  • BOW DOWN TO MY MIGHTY STARE!!
« Reply #5 on: February 09, 2009, 03:50:39 PM »
nice. looks like that eye thing in big brother. where will it be used
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
Offline Spoil9
« Reply #6 on: February 09, 2009, 04:40:15 PM »
Very nice. Which airsoft gun did you start with? I'm assuming you got one that is battery powered so you can activate the trigger with a pulse from the MCU?
I have thought of doing this as well, but can not find a cheap enough airsoft pistol around here that is battery powered that I wouldn't mind hacking up.
  • Helpful? 53
« Reply #7 on: February 09, 2009, 04:42:46 PM »
Yeah, it's one of those cheap no-name brand electric airsoft guns. I got mine in a two pack with a pistol for $30 at wal-mart a while back.
  • Helpful? 53
« Reply #8 on: February 10, 2009, 06:59:14 PM »
Getting a basic mockup of the tilt mount done, final one might be acrylic. It will be mounted on a rotating base (for pan). I used brackets from budgetrobotics.
Offline izaktj
« Reply #9 on: February 10, 2009, 10:06:51 PM »
Dude I've always wanted to do something like this!!
Offline Joesavage1
« Reply #10 on: February 11, 2009, 11:23:11 AM »
Cool!
  • Helpful? 53
« Reply #11 on: February 15, 2009, 01:50:28 PM »
I ran out of shampoo and got a great idea at the same time  ;)
  • Helpful? 11
« Reply #12 on: February 15, 2009, 03:09:37 PM »
Razor Concepts used the  " Pulse-M70 " fully automatic electronic airsoft gun...(i think...its made by a company called Crosman)
« Last Edit: February 15, 2009, 03:21:10 PM by Metal Slug 2 »
« Reply #13 on: February 18, 2009, 02:11:41 AM »
trash the relay and just use a MOSFET alone . . . relays are useless today except for high powered stuff. 8)
Where did you buy the airsoft gun at? ERP could sure use a Predator style shoulder mount cannon . . .
Offline airman00
« Reply #14 on: February 18, 2009, 05:58:51 AM »
just look online for the electric airsoft guns, they're everywhere!
  • Helpful? 53
« Reply #15 on: February 18, 2009, 11:12:29 AM »
I got mine at wal-mart or target. Dont spend over $30 for one or else its not worth it.
  • Helpful? 53
« Reply #16 on: February 18, 2009, 09:18:33 PM »
Added transistor to drive relay as airman suggested:
  • Helpful? 53
« Reply #17 on: February 20, 2009, 06:48:46 PM »
Finally got some PVC sheet to replace the wood.
« Reply #18 on: February 20, 2009, 07:23:20 PM »
wow, that looks great! but what does the bottle do? mag? air tank??
  • Helpful? 11
« Reply #19 on: February 20, 2009, 09:40:49 PM »
The bottle is used as a hopper, or a mag if u prefer....dont know why such a big one would be needed though...that thing could hold probably 2000+ BB's easily.
Offline 4by4
« Reply #20 on: February 21, 2009, 08:51:14 AM »
Razor, what's your experience with the reliability of the gun? I've been working on a couple of RC vehicles that originally had airsoft turrets, but the guns got jammed so often, I abandoned them and have switched to IR laser-tag guns. The airsoft guns I used were the cheap ones used in Heng Long tanks. They jammed all the time, and had awful range. I also tried a $20 gun from Walmart, which was also pretty worthless. It had a better range, but jammed a lot also.
  • Helpful? 53
« Reply #21 on: February 21, 2009, 09:27:12 AM »
The original unmodifed gun could only hold 84 BBs. Not enough for me  ;D
I've used the gun unmodified for a long time, it has never jammed, although the original BB feeding system would get stuck so you would have to shake the gun a bit to get the BBs to roll down into the chamber. I added the front-feeding system on this to get rid of that problem.
Offline HyperNerd
  • N3rd1n80r
« Reply #22 on: February 21, 2009, 11:37:30 AM »
if you use cheap BBs then they are not always perfectly round, so get wedged in the barrel. More expensive BBs are more round, so don't have this problem. This should even work with cheap BB guns.
 -HyperNerd
There are 10 types of people in the world - those who understand binary, and those who don't.
  • Helpful? 53
« Reply #23 on: February 28, 2009, 01:52:26 PM »
Added a base and made a pitch control system using a servo and ball linkages.
Video: (Sorry for the South Park in the background, I fogot to pause it  :-X )
« Reply #24 on: February 28, 2009, 03:29:53 PM »
wow, i like the way you made the gun pivot are you going to add another rotation axis?
Offline TrickyNekro
  • Helpful? 15
  • 1.6L Peugeot 307 tuner
« Reply #25 on: February 28, 2009, 05:38:40 PM »
I really feel like it needs more space to move... a bigger angle range.... really....
Except from that.... everything else just more than fine....
Cheers!
Offline Joesavage1
« Reply #26 on: March 01, 2009, 01:05:39 AM »
I also agree, it looks like it needs to move more, on the different axis as previously said.
« Reply #27 on: March 03, 2009, 06:47:32 AM »
Use a small vibrating motor, like a pager motor. Have it turn on this motor after every few shots . . . I see this done on feeder systems all the time.
  • Helpful? 11
« Reply #28 on: March 03, 2009, 09:20:04 PM »
awesome, Thats a great idea... :)
  • Helpful? 53
« Reply #29 on: March 07, 2009, 07:01:36 PM »
Changed location of ball link to get more pitch throw, and finally came up with an idea for pan. I used a budgetrobotics servo mount on it's side to hold the pan servo. Sorry for poor video quality, I misplaced my camera so I had to use my mp3 player
http://vimeo.com/3519983
EDIT: Just found it, took better pics and video.
http://vimeo.com/3520224
« Last Edit: March 07, 2009, 07:29:18 PM by Razor Concepts »
