Squirrels have fuzzy tails.
where are you getting 12VAC from?!?120VAC sounds dangerous . . .oh, and just know that if you step up voltage, you will also end up stepping down current . . .
lol, admin only current is dangerous, you can get millions of volts(i think) but if you get more then 50 milliamps you will die.
Also do transformers change alternating current into direct? i know they dont work with direct current.Also wouldnt a transformer with a "Step up" set up raise the voltage?
Quote from: gamefreak on March 05, 2007, 07:35:02 PMAlso do transformers change alternating current into direct? i know they dont work with direct current.Also wouldnt a transformer with a "Step up" set up raise the voltage?Xfmrs use AC for the input and also outputs AC. Also you are correct that a transformer set up as a "step-up" would increase the voltage while lowering the current. the basic relashinship for a Xfmr is: (V1/V2)=(I2/I1)=a where a= the turns ratio (ie. N1/N2 where N= coil turns), V=volts, I= current and 1 is the primary/input side, 2 is the secondary/output side.
Wait! dont normal house hold plugins give off 120 VAC?
Started by corrado33 Electronics
