Author Topic: how to control encoder in labview  (Read 4254 times)
Offline robotaTopic starter
« on: February 10, 2009, 06:31:05 PM »
Hallow friends
I am new with labview
I want to learn how I control an encoder with labview
Tanks
Offline pomprocker
Re: how to control encoder in labview
« Reply #1 on: February 11, 2009, 11:17:28 AM »
usually encoders get hooked up with a motor and the signal goes to an MCU. I don't know of any labview compilers for an MCU.
« Reply #2 on: February 13, 2009, 01:37:29 AM »
LabView lets you hook up devices called a DAQ, of which has lots of I/O to do stuff with.
You could also just you any microcontroller and have LabView read in data that you send it. (a DAQ has a built in microcontroller)
Offline amir.ali
« Reply #3 on: January 02, 2010, 03:51:55 AM »
you can use the encoder with the labVIEw , through DAQ you need to use the DAQmx from the Block Diagram on the LabVIEW then choose acquiring signals, then select count edges and connect it from the DAQ...
Offline g44
« Reply #4 on: January 04, 2010, 04:37:30 PM »
I search after more forums that have people that know labview
Also I search after people around all the world that teach labview
Offline g44
« Reply #5 on: January 14, 2010, 04:59:34 PM »
I search after names of books that explain How to program things that related to robotics in labview software
Last post May 14, 2007, 07:31:55 AM
by fang-wei
Last post January 23, 2009, 11:14:16 AM
by die-0dd
Last post July 23, 2009, 12:00:22 PM
by muya
Last post July 23, 2009, 01:24:20 PM
by Webbot
