Author Topic: Life time expectancy of an Atmega8 (or similar)? (solved)  (Read 1321 times)
Offline Metal Slug 2Topic starter
  • Helpful? 11
« on: February 10, 2009, 11:13:12 PM »
I was just wondering.....if you were to for example use a $50 robot board with an Atmega8 and have it hooked up to a continuous 6v power supply, program in for example a 'stampy' algorithm and run if 24/7.  How long would the circuit survive for (or more specifically, the Atmega8), assuming there is no disrupting interference with it?
« Last Edit: February 11, 2009, 01:19:07 AM by Metal Slug 2 »
Offline householdutensils
Re: Life time expectancy of an Atmega8 (or similar)?
« Reply #1 on: February 10, 2009, 11:17:24 PM »
From the Datasheet:
Data retention: 20 years at 85°C/100 years at 25°C
That value is defined as:
Reliability Qualification results show that the projected data retention failure rate is much less
than 1 PPM over 20 years at 85°C or 100 years at 25°C.
I don't know if that's what you want, but it seems relevant :D
« Last Edit: February 10, 2009, 11:21:12 PM by householdutensils »
« Reply #2 on: February 10, 2009, 11:19:55 PM »
Sorry!! Hit the quote button instead of the modify button  :-X
  • Helpful? 11
« Reply #3 on: February 11, 2009, 01:16:23 AM »
Wow, thats much longer than I expected!  Awesome, :)
Thanks.
Re: Life time expectancy of an Atmega8 (or similar)? (solved)
« Reply #4 on: February 11, 2009, 08:56:11 AM »
Depends on how much you write to memory. RAM will fail after so many rewrites, check the datasheet. I think the number was in the millions or billions.
EEPROM will fail after about ~100,000 rewrites.
Of course this follows a bell curve, not an exact number.
Offline pomprocker
« Reply #5 on: February 11, 2009, 10:54:57 AM »
the hardware aspect may also fail. Not sure how long servos can survive after constant use
EDIT:  But like any good technician attending to a piece of machinery, there is always scheduled preventative maintenance.
« Last Edit: February 11, 2009, 10:55:52 AM by pomprocker »
« Reply #6 on: February 15, 2009, 05:51:30 AM »
good question!
http://www.societyofrobots.com/robotforum/index.php?topic=1300.0
Last post May 03, 2008, 07:46:01 PM
Last post September 14, 2009, 03:34:59 PM
by Half Shell
Last post February 21, 2011, 09:52:57 PM
by dmclifton
Last post October 07, 2012, 10:24:38 AM
by waltr
