Author Topic: Servos are running slow  (Read 1478 times)
Offline Its_FridayTopic starter
« on: February 11, 2009, 07:46:19 PM »
I am using the axon microcontroller. When i plug in one servo, it runs at a decent speed. But when i plug in a second servo, for 1 second they run at normal speed, but then they slow down. They maintain that slower speed.
Why can one servo run fast, but 2 servos can't? They're hooked up to the microcontroller, and the microcontroller is hooked up to a 7.5 volt battery pack. My best guess is that the batteries can't provide the needed amperage. Whatever the problem maybe, how can i fix this? ???
Offline Jdog
Re: Servos are running slow
« Reply #1 on: February 11, 2009, 07:58:45 PM »
Try plugging in the 2 servos and measure the voltage of another output port, turn on the axon and see if there is a drop in voltage. If not Try it with a different battery pack and see if it still happens. You could even use a cheap $2 4 AA holder battery pack and try that. I know that 4 AA batteries definitely has enough amperage so try that and report the results. If that doesn't work, try writing a program to control three servos and read one adc port and print out the data, plug in your two servos and make a jumper wire from the signal wire of the other servo port to the input wire of the adc port and analyze the signal with the SOR Scope.
« Reply #2 on: February 11, 2009, 11:26:48 PM »
what type of battery, and whats the mAh on it? is the battery fully charged?
« Reply #3 on: February 12, 2009, 02:13:49 PM »
It's a 7.5V 1200 mAh NiMH Battery Pack
« Reply #4 on: February 12, 2009, 08:02:15 PM »
Hmmm what servos are you using?
This battery should be enough . . . is it fully charged?
Are you controlling the servos through the ADC pins or the non-regulated pins?
« Reply #5 on: February 12, 2009, 09:02:14 PM »
I figured out the problem.The battery is no good. Even though i measure it at 7.5V right out of the charger, it can't last more then a minute when running the servos. Thankfully i bought a spare battery that works properly.
Last post February 14, 2008, 07:34:39 PM
by harisankarsa
Last post September 21, 2008, 06:40:33 PM
Last post December 22, 2009, 04:05:13 PM
by weighates
Last post January 05, 2010, 01:02:34 AM
