Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
#include <avr/io.h>int main(){ DDRA = 0b00000100; DDRB = 0xff; ADCSR |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0); // Set ADC prescalar to 128 ADMUX |= (1 << REFS0); // Set ADC reference to AVCC ADMUX |= (1 << ADLAR); // Left adjust ADC result to allow easy 8 bit reading ADMUX |= (1 << MUX0); // Set ADMUX to sample ADC1 ADCSR |= (1 << ADFR); // Set ADC to Free-Running Mode ADCSR |= (1 << ADEN); // Enable ADC ADCSR |= (1 << ADSC); // Start A2D Conversions unsigned char sensor=0; while(1){ sensor = ADCH; PORTB = sensor; if(sensor > 122){ PORTA=0x04; } else { PORTA=0x00; } }}
Does the adc continuously read? if not then youve only told the adc module to read once. everytime you copy the register then you are only copying the initial reading.try puttingADCSR |= (1 << ADSC); // Start A2D Conversionsinside the while loop
Started by Botanic Electronics
Started by Rebelgium Robot Videos
Started by Charizard Software
Started by greasemonkey94 Software
