Author Topic: Weird Op Amp thing.........  (Read 2075 times)
Offline TrickyNekroTopic starter
  • Helpful? 15
  • 1.6L Peugeot 307 tuner
« on: February 13, 2009, 10:55:54 AM »
Hello guys,
I'm building an op amp circuit for a current sensor...
I'm pulling up the output pin with a 1k resistor...
I just noticed that when the input is more than a certain value the
output becomes higher than 5V!!!! And I'm powering in with only 5V!!!!
How the..... is this possible?????
Is a zener diode a good way to prevent this from happening, cause I'll be measuring the
output with an ADC????
Thanks in advance,
Lefteris
Greece
Cheers!
Offline galannthegreat
Re: Weird Op Amp thing.........
« Reply #1 on: February 13, 2009, 02:08:54 PM »
Try a general diode, such as a 1N4001, and test the voltage drop, that should work.
Kurt
Offline chelmi
  • Helpful? 15
« Reply #2 on: February 13, 2009, 02:57:45 PM »
Please post a schematic of circuit, there are many different ways of using an op-amp.
An op-amp amplifies, an output voltage higher than its input is not surprising...
Chelmi.
  • Helpful? 15
« Reply #3 on: February 13, 2009, 03:00:40 PM »
a diode in series is a little bit bad for the accuracy I want...
I only measure 0 Amps to 1-1.5Amps so I don't have a problem with the zener...
Cause this happens after 3Amps are being drawn...
It;s somethings I lack...
Like if I need a current limiting resistor with my zener and such...
And basically I need to know why this happens....
Thanks for your reply,
Lefteris,
Greece
Cheers!
  • Helpful? 15
« Reply #4 on: February 13, 2009, 03:02:25 PM »
Chelmi.
Higher than input yes....
Higher than supply no...
The supply is 5V and the output goes to ~5V6!!!!
That's confusing...
I'll post a schematic right away...
Cheers!
Offline chelmi
  • Helpful? 15
« Reply #5 on: February 13, 2009, 03:26:08 PM »
Chelmi.
That's confusing...
Oops, I misread your first post :)
  • Helpful? 15
« Reply #6 on: February 13, 2009, 05:06:31 PM »
Here are the schematics.... hope this helps....
Cheers!
« Reply #7 on: February 14, 2009, 01:45:49 AM »
I'm a bit puzzled over your schematic.
Is the Vref supposed to be the input?
Why did you connect R2 and R3 to pin 1? Shouldn't they connect to pin 2 instead?
What kind of circuit are you trying to build? An amplifier or...?
As far as I see it, you have connected it in a wrong way, you have a feedback resistor to the inverting input and a voltage divider on the supply with the tap on the output. I don't see what you want to accomplish with that.
Remake the circuit first and if it still goes higher than supply, then add a 10..100nF cap directly over the supply pins. Next step is decoupling the input(s) with small caps (in the pF range).
If you look at the output with a 'scope, I have a hunch that you'll find it oscillating wildly.
  • Helpful? 15
« Reply #8 on: February 14, 2009, 03:52:41 AM »
It's an non-inverting schematic....
If I don't use the R3 the output never goes over 3V8 volts and that's a problem....
It's to boost the output....
It's not something that I really got out of my head.... I once used a resistor in the same configuration
for an voltage comparator circuit.... to boost the output.... So I guessed that would be ok.....
I get the feeling that it is oscillating badly too.....but I don't have a scope to see it..... (BAD!!!!)
Usually, in current sensors I see a 100nF between inverting and non-inverting inputs....
And of course one for decoupling the power pins.... (Which I include in the real circuit)
Lefteris,
Greece
Cheers!
  • Helpful? 15
« Reply #9 on: February 14, 2009, 05:16:51 AM »
Ok... Problem solved..... new created.... but that's another thing.....
Thanks for the help guys!!!!!
Cheers!
« Reply #10 on: February 14, 2009, 07:33:00 AM »
]It's not something that I really got out of my head.... I once used a resistor in the same configuration
It is not an inverting amp.
I rearranged your circuit to make it more clear. Your circuit on the left, the real inverting amp on the right:
When using a comparator (not an op-amp) you sometimes have to use a pull up, since some comparators has got an open collector output (same as if you had a loose NPN transistor with the emitter to Gnd, driven from the base and with the collector just sitting there).
On an op-amp, you just load the output by placing a pull up (or pull down) resistor.
What did you do to solve it and what is the new problem?
Admin <- why are images shrinked a wee bit in the posts, making the semi-unintelligible?
  • Helpful? 15
« Reply #11 on: February 15, 2009, 07:26:20 AM »
I know that the real circuit is at the right....
But the output won't go more than 3V8...
And that is problematic.....
Cheers!
« Reply #12 on: February 15, 2009, 01:57:49 PM »
You'll need an op-amp with rail to rail output.
  • Helpful? 15
« Reply #13 on: February 15, 2009, 05:57:07 PM »
Any recommendation?
Cheers!
« Reply #14 on: February 15, 2009, 07:06:23 PM »
One of the MAX416x would do
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1696
They come in single, dual and quads in PDIP (Plastic DIP, I guess they are what you want).
« Reply #15 on: February 17, 2009, 12:17:05 PM »
If you go to mouser.com and search for op-amps, there will be an option to filter by rail-to-rail output.
Last post August 10, 2010, 08:25:38 PM
by Cybran
Last post May 09, 2011, 07:31:47 PM
by Kylepowers
Last post June 16, 2011, 12:13:37 PM
by mstacho
Last post October 21, 2012, 07:53:16 AM
by studyembedded
