Author Topic: Low Voltage Stepper  (Read 1013 times)
Offline vivek9856Topic starter
Low Voltage Stepper
« on: February 14, 2009, 09:45:19 AM »
I have to drive a 1.5 A stepper motor off of a 4 AA cell power source. (4.8V because I'm using NiMH batteries)
What motor driver should I use? I don't think the L298 would work because it would require a higher supply voltage. So what does everyone else suggest? I will be using an ooPIC to drive the motor, and was initially planning on using an L297 to run the motor driver.
Re: Low Voltage Stepper
« Reply #1 on: February 15, 2009, 09:07:45 PM »
You need a stepper motor driver. For example:
http://www.sparkfun.com/commerce/product_info.php?products_id=8368
(note, I didn't verify it can handle your required current)
Offline ib1yysguy
« Reply #2 on: February 15, 2009, 09:19:02 PM »
I think is problem is that the stepper driver that you linked to requires 7-20 or 30 volts to operate. He's running on 4.8.
Can he just amplify the voltage for that part of the circuit at a cost of amps?
« Reply #3 on: February 15, 2009, 09:32:27 PM »
hmmmm I can't read . . .
# Adjustable current control from 150mA/phase to 750mA/phase
# Power supply range from 7V to 30V.
Have a search through these (all 5 pages), you might find something:
http://th.mouser.com/Search/Refine.aspx?N=1323043&Keyword=%22stepper+motor%22&FS=True
Last post August 26, 2006, 04:32:58 PM
by waldir
Last post May 20, 2007, 03:45:04 PM
by JonHylands
Last post July 18, 2007, 03:38:32 AM
by dunk
Last post January 25, 2008, 01:52:12 AM
by Bubbles
