Author Topic: $50 expansions  (Read 1553 times)
Offline Joesavage1Topic starter
$50 expansions
« on: February 15, 2009, 06:59:08 AM »
I was just thinking and had a couple of ideas. First of all if i decided i wanted the robot to follow IR light then if i replaced the photocells with IR detectors, and then used a TV remove or something to control it would this work?
Second of all i belive there are spare microcontroller ports or chips or wtv (the connectors) left on the sensors and servos side of things, could these be used as a $50 expansion (obviously with a slightly modified code)?
Third, is it possible using the thing above that i could make some of the extra servo's remote controlled or would this need some type of reciver instead of using a microcontroller?
(You can post some cool expansion ideas too if u like =D)
Joe
Offline cooldog
Re: $50 expansions
« Reply #1 on: February 15, 2009, 07:16:56 AM »
if you replace the photocells with ir range finders they will follow ir light without any modification to the code, but i am unsure about being able to control the robot useing a remote
-admin
favorite web sites
http://www.instructables.com/
Offline RiffRaff
Re: $50 expansions
« Reply #2 on: February 15, 2009, 09:04:38 AM »
Joe,
There are 5 servo ports and 6 sensor ports on the microcontroller, so there is some room for expansion.  What I was wondering is whether a modified version of the microcontroller board(from the $50 robot) could easily be built with more ports for servos?  Say, with a larger microcontroller chip, maybe?
I want to build a biped robot, and the design I want to play with requires 6 servos just for the legs.
Riff
Re: $50 expansions
« Reply #3 on: February 15, 2009, 10:10:19 AM »
Basically all the pins on the microcontroller have the capability of driving servos - just modify the configure_ports() method to change the ports to an output.
Offline RiffRaff
Re: $50 expansions
« Reply #4 on: February 15, 2009, 10:28:04 AM »
Oh, how cool is that?  Is the modification something done in the programming?
And let me apologize here for all the stupid questions that I'm going to ask.  I am into robots for the long haul, but I have a LOT to learn.
Riff
Re: $50 expansions
« Reply #5 on: February 15, 2009, 10:33:47 AM »
Yep. In the datasheet for the mega168 they have a list of the pins and what they can do.
Offline RiffRaff
Re: $50 expansions
« Reply #6 on: February 15, 2009, 12:18:17 PM »
Is the same true of the ATMEGA8-16?
Offline RiffRaff
Re: $50 expansions
« Reply #7 on: February 15, 2009, 12:24:28 PM »
Looking at the ATMEGA8 datasheets I see that ports B,C & D are all I/O ports.  So that's 23 I/O ports, 8 8-bit ports, 7-7bit ports and however many (out of 8) 8-ports you can use in place of whatever 'special functions' you won't need.
All in all that give me plenty of servos for running a bi-ped walker.
