Author Topic: $50 help with electronics  (Read 20635 times)
Offline Joesavage1Topic starter
Re: $50 help with electronics
« Reply #60 on: March 01, 2009, 01:48:53 AM »
Yer, it looks like the ones at the top. BTW, i dont want to have to buy a molex or wtv.
« Last Edit: March 01, 2009, 01:49:56 AM by Joesavage1 »
« Reply #61 on: March 01, 2009, 02:17:03 AM »
well i guess you could just tape the wires on... or if you dont mind it being permanent you could desolder the pin and solder the wire there. but i really do recommend getting the crimps and a crimper. mine was $6us and works like a dream :) i got mine from futurlec for really cheap
pin 10 pack part no: HDPINF
3 pin housing part no: HDCONNS3
if you think you will continue with robotics or electronics in general i recomend you get like 10 of each so you get a discount. they're just plain handy to have around! ;)
« Reply #62 on: March 02, 2009, 10:02:56 AM »
ill solder them for now, but how do i go about soldering them on?
Also i will buy with my next project/purchase i make with an online electronics store, but its getting tiring keep having to redo p&p for now.
Thanks In Advance
Joe
« Reply #63 on: March 02, 2009, 10:06:26 AM »
Just get some free samples of female breakaway headers. I got a bunch and use them for unimportant things, and I use the molex connectors and crimpers for more important stuff.
« Reply #64 on: March 02, 2009, 10:07:08 AM »
o have the breakaway headers, but what bits do i solder where??
« Reply #65 on: March 02, 2009, 10:11:11 AM »
Female breakaway headers is what I'm talking about. Do not solder to your male breakaway headers because you won't be able to plug anything in them later on.
« Reply #66 on: March 02, 2009, 11:45:38 AM »
oh, well as i said i dont wanna but anything more, so female headers is even more out of the question as i may aswell do it the other way if i way going to buy anything..
I need a solution were i dont have to buy anything extra but it dont look to ghetto either.
Thanks In Advance
Joe
« Reply #67 on: March 02, 2009, 12:41:55 PM »
No no, read more carefully  ;D
« Reply #68 on: March 02, 2009, 12:57:01 PM »
theres always 'sampling' to be had joe!
Offline chelmi
« Reply #69 on: March 02, 2009, 12:59:43 PM »
Thanks In Advance
Joe
Just solder the cable to the board in this case...
« Reply #70 on: March 02, 2009, 01:31:39 PM »
yea that too. i guess if you ever get bored you could desolder the wires or attach them to a female molex :-\
« Reply #71 on: March 03, 2009, 09:28:38 AM »
What cables? i see two metal terminals on the bottom thats all. (btw if your reffering to the link, then is there another way that i dont have to mess around with extra wires and things?)
Joe
Offline chelmi
« Reply #72 on: March 03, 2009, 12:58:01 PM »
The cable between the photoresistor and your board. If you attach the photoresistor directly to the board you wont be able to position it correctly on each side of the robot.
Well, I don't follow you here. You have to physically connect you sensor to you MCU! there is no magic, you need a cable!
Honestly, if you want to build a robot, you have to deal with cables!!! It's part of the fun!
Chelmi.
« Reply #73 on: March 03, 2009, 01:00:44 PM »
ahh you stopped me posting chelmi!
anyway. ok so you've got your photosensor, your resistor and your 3 wires. solder one wire to each leg (red and signal) then below one of the wires solder the 1k resistor, on the end of this solder the gnd wire. i am not sure about this but i think thats the way it goes. someone confirm this?
« Reply #74 on: March 03, 2009, 04:12:59 PM »
So Vout would go to the signal pin, Vin would go to positive 5v, and GND (the three line things) go to ground.
Or basically what smash said is correct.
« Last Edit: March 03, 2009, 04:14:04 PM by Razor Concepts »
Offline dellagd
« Reply #75 on: March 03, 2009, 09:07:54 PM »
you guys got it.
just a few words of advice.
If you have a desoldering tool, use it carefully on the board, the whole copper soldering ring on it may get sucked off(bad experiences).
then it is way harder to solder your components on ;)
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
« Reply #76 on: March 03, 2009, 11:27:52 PM »
you guys got it.
same thing happened on my first $50 board. the four solder rings in between power and 5v reg got melted off. so ill try and jumper it sometime :-\
« Reply #77 on: March 04, 2009, 10:04:02 AM »
Ok, the Vin and Vout thing confused me, also can u repeat the wire with resistor thing explanation it also confused me (i know im easilly confused!).
Also..
Lol, that made me laugh for a while; I will use the wire way when i fully understand.
Joe
« Reply #78 on: March 04, 2009, 12:29:21 PM »
"vin" is voltage in
"vout" is voltage out
"gnd" is ground
so vin is +, vout is signal in this case?, gnd is negative power.
« Reply #79 on: March 05, 2009, 08:29:24 AM »
"vin" is voltage in
"gnd" is ground
Can you just explain it in simple terms for now? without the Vin And Vout.
Joe
« Reply #80 on: March 05, 2009, 11:33:43 AM »
GND connects to the outer row of headers (ground)
VIN connects to the middle row of headers (+5 power)
Vout connects to the inner row of headers (connected to MCU pins)
« Reply #81 on: March 05, 2009, 12:37:10 PM »
No Offence, but I asked for insturctions without the whole Vin and Vout Thing, just while im making, ill figure out how that bit works after
Joe
« Reply #82 on: March 05, 2009, 01:21:20 PM »
okay then, arrange them like this:
GROUND
+5V
SIGNAL
okay so it doesnt matter to much as long as the +5v is in the middle because you can always flip the header around cant ye?
Offline chelmi
« Reply #83 on: March 05, 2009, 01:36:20 PM »
Joe
Really, there is no other way to explain it other than looking at the schematic and identifying the wires (If Vin and Vout confuse you, name them 1, 2, 3 or alice, bob, carol whatever).
This is a really simple circuit, resistors don't have polarity. Put you component on the table and try to mimic the schematic given by Razor. If it helps, draw it on a piece of paper and lay the component on the schematic. Then solder the junction between the resistor and the photresistor. Now connect each point of the circuit to the corresponding pin with a piece of wire, as explained by Razor.
Chelmi
PS: my advice: don't rush. If you don't understand how this circuit works, take some time to learn basic electronic. It will really save you time later. If you build your bot without understanding how it is supposed to work, you will likely screw something up. And since you will have no idea of how it is supposed to work, you won't be able to debug it. This is going to be very frustrating.
This one seems good: http://www.ikalogic.com/beg_1_res_v_c.php
Offline dellagd
« Reply #84 on: March 05, 2009, 02:50:59 PM »
I have another question about the circuit.
how come there are 3 dots colored pink on the microcontroller?
which go to which?
I Won!
Offline householdutensils
« Reply #85 on: March 05, 2009, 03:31:25 PM »
which go to which?
All those contacts should be connected to your 5v power bus.
« Reply #86 on: March 06, 2009, 01:34:24 AM »
GROUND
+5V
SIGNAL
How do i arrange them like that???? I see 2 terminals, which one is +5v whats GND and whats SIGNAL.?
Sorry For Noobishness
Joe
Offline chelmi
« Reply #87 on: March 06, 2009, 09:59:37 AM »
GROUND
+5V
SIGNAL
Joe
http://www.societyofrobots.com/robotforum/index.php?action=dlattach;topic=3292.0;attach=2439
We are talking about sensor inputs.
blue is signal
black is ground
+5V is mauve
« Reply #88 on: March 08, 2009, 06:39:21 AM »
GROUND
+5V
SIGNAL
Joe
blue is signal
black is ground
+5V is mauve
I know, but which wires go where???
« Reply #89 on: March 08, 2009, 10:46:31 AM »
Wires are all labeled here
