Author Topic: $50 help with electronics  (Read 12936 times)
Offline chelmi
Re: $50 help with electronics
« Reply #90 on: March 08, 2009, 11:38:32 AM »
okay then, arrange them like this:
GROUND
+5V
SIGNAL
okay so it doesnt matter to much as long as the +5v is in the middle because you can always flip the header around cant ye?
How do i arrange them like that???? I see 2 terminals, which one is +5v whats GND and whats SIGNAL.?
Sorry For Noobishness
Joe
http://www.societyofrobots.com/robotforum/index.php?action=dlattach;topic=3292.0;attach=2439
We are talking about sensor inputs.
blue is signal
black is ground
+5V is mauve
I know, but which wires go where???
Can you be more specific? go where on the board or on the sensors?
Did you open the document I linked? This cannot be more explicit... You have to make an effort, I wont solder the parts for you...
Chelmi.
« Reply #91 on: March 09, 2009, 03:13:12 AM »
here this clear it up a bit? left middle and right are how to arrange them in the molex. the resistor is the 1.6k or something one.
Offline paulstreats
  • Helpful? 20
« Reply #92 on: March 09, 2009, 10:40:39 AM »
that drawings wrong smash. Where you have the Vin wants to be the Vout(where it connects to the adc pin).
Vin and GND should be connected to the other 2
« Last Edit: March 09, 2009, 11:09:59 AM by paulstreats »
Offline Joesavage1Topic starter
« Reply #93 on: March 09, 2009, 01:01:31 PM »
I just wanna know were i connect the wires to the terminals, then where i connect them to the board.... Vin and Vout for now confuses me, at the end of the project ill re look over it.
Joe
Offline paulstreats
  • Helpful? 20
« Reply #94 on: March 09, 2009, 01:24:43 PM »
Heres a picture. The big black thing on the bottom is the connector. plug the wires into it in that order.
black     = GND
red wire = +5v
yellow    = Vout / signal
When you plug it into your board the yellow wire wants to go closest to the microcontroller (connects to the adc pin)
« Last Edit: March 09, 2009, 01:26:44 PM by paulstreats »
« Reply #95 on: March 09, 2009, 01:29:29 PM »
isnt that what mine says? please clear up how mine is wrong. mine has +5v in the middle? or was my writing wrong?
Offline paulstreats
  • Helpful? 20
« Reply #96 on: March 09, 2009, 01:33:26 PM »
The Vout should be from between the resistor and photocell
« Reply #97 on: March 09, 2009, 01:37:16 PM »
ohhh, i thought it wouldnt matter because theyre non polarised. does the resistor somehow affect the reading?
Offline paulstreats
  • Helpful? 20
« Reply #98 on: March 09, 2009, 01:45:31 PM »
Yes. If you didnt need the resistor It wouldnt be there.
The photocell doesnt adjust the voltage, it only adjusts how much current can pass through(changes resistance in proportion to the light), the same with the resistor. The adc ports need a change in voltage so by connecting the resistor in the correct way, it causes the voltage to change depending on how much light is on the photoresistor
« Reply #99 on: March 09, 2009, 01:49:46 PM »
i know that but does the resistor affect the reading on the signal line, so does it matter which side is signal, resistor or no resistor?
Offline paulstreats
  • Helpful? 20
« Reply #100 on: March 09, 2009, 01:54:49 PM »
Yes, the vout/signal of a voltage divider needs to come from between 2 resistors (in this case the photocell is a resistor).
« Reply #101 on: March 09, 2009, 01:56:42 PM »
ok that clears things up a bit! thanks mate :D
« Reply #102 on: March 13, 2009, 09:21:43 AM »
Ok, that clears it up for the moment (although im not even onto doing this bit yet, i was asking upfront), ill ask if I have any more questions.
Thanks Guys!
Joe
« Reply #103 on: March 25, 2009, 12:52:17 AM »
nothing is acctuly connected, there just all soldered onto the board?
yeap
Last post June 30, 2009, 09:25:52 AM
Last post July 03, 2009, 08:58:48 PM
by MangoBot
Last post December 17, 2009, 02:27:46 PM
by GearMotion
Last post March 23, 2010, 11:05:35 AM
by stripboard
