Author Topic: PC fan question  (Read 1608 times)
Offline cloneTopic starter
PC fan question
« on: February 16, 2009, 02:04:23 AM »
OKAY.. so i have a question about PC fans... when you take them out of ur computer, they have 3 wires.  usually red black and yellow.
what is the 3rd wire for?? is it a temperature indicator? or a fan speed monitor?? what can i use this third wire to do??
thnx, dave
Offline HDL_CinC_Dragon
Re: PC fan question
« Reply #1 on: February 16, 2009, 02:05:15 AM »
the yellow wire is for fan speed monitoring
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Re: PC fan question
« Reply #2 on: February 16, 2009, 02:06:56 AM »
excellent.. so what kind of signal does it send out.. does it send out a certain voltage or resistance that would indicate the speed?? how would i hook it up to an arduino board to detect fan speed?
Re: PC fan question
« Reply #3 on: February 16, 2009, 02:08:48 AM »
not really sure TBH... Im going to assume it would be a digital signal which the PC counts the on and offs per second... ive never hooked up an O-Scope to it to be sure.
try googling it
Infantry
Offline Razor Concepts
  • Helpful? 53
Re: PC fan question
« Reply #4 on: February 16, 2009, 11:04:24 AM »
It's some kind of frequency counter output. Look here
http://en.wikipedia.org/wiki/Computer_fan
Re: PC fan question
« Reply #5 on: February 18, 2009, 01:34:26 AM »
As with all electronics hacking, if you don't know what signal it gives out, hook it up to a multimeter :P
Offline frodo
  • BOW DOWN TO MY MIGHTY STARE!!
Re: PC fan question
« Reply #6 on: February 18, 2009, 05:04:36 AM »
i am not very good with multimeters and have googled which didn't return much (nothing), so how do you test which signal something sends with a multimeter?
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
Re: PC fan question
« Reply #7 on: February 18, 2009, 05:09:08 AM »
You definitely need a multimeter to make robots!
Put the black wire on ground, and the red wire on the wire you want to test. Then set the multimeter to the test you want. Use google to learn more about how to use a multimeter :P
Offline fuzzyt
Re: PC fan question
« Reply #8 on: February 19, 2009, 10:28:26 AM »
Last post July 13, 2009, 05:53:41 AM
by dellagd
Last post July 26, 2009, 08:13:52 PM
by wil.hamilton
Last post August 12, 2009, 12:57:09 AM
by Razor Concepts
Last post December 22, 2009, 04:26:38 PM
by little-c
