Author Topic: Swap Spline Gear?  (Read 2451 times)
Offline ajayreTopic starter
Swap Spline Gear?
« on: February 19, 2009, 12:18:48 AM »
Is it possible to swap a 23 tooth spline gear on a GWS servo for a Hitec 24 tooth or Futaba 25 tooth spline gear? Are there conversion kits somewhere?
The reason I ask is that I want a 1/4" shaft on my GWS servo, like this one:
  http://www.servocity.com/html/servo_shaft_attachment.html
My GWS servo is this:
  http://www.acroname.com/robotics/parts/R298-1T-SERVO.html
Any ideas?
thanks, Andy
Re: Swap Spline Gear?
« Reply #1 on: February 19, 2009, 07:01:41 AM »
From my experience GWS and Futaba servos have the same spline design so that you can interchange servo horns between them.
If they aren't compatible, chances are you won't be able to swap the gears out - the gears are made for the servo, so if a gear is just a little different from the original, the gear mesh will be messed up.
« Reply #2 on: February 19, 2009, 09:22:34 AM »
Thanks, although I am a bit confused. This discussion:
  http://www.rcgroups.com/forums/showthread.php?t=934716
seems to indicate that most GWS servos are compatible with JR servos. Then this page:
  http://www.rmfm.org/servo_arms.htm
says that JR splines have 23 teeth. This matches with what the web page for my servo says. I'm very confused now.
Andy
« Reply #3 on: February 19, 2009, 11:43:30 AM »
looks like GWS varies. In the RC groupd thread you listed, two different GWS reps posted and they posted conflicting information (one said futaba is most common, other said JR). I would bring your servos to a hobby store and have them find which one your servos have.
Last post June 19, 2008, 09:31:22 AM
by silent069
Last post January 27, 2009, 12:35:55 AM
Last post June 13, 2011, 04:04:35 PM
by Remix
Last post July 05, 2011, 10:57:03 AM
by heinz357
