Author Topic: Roboduino Battery?  (Read 1306 times)
Offline offyTopic starter
Roboduino Battery?
« on: February 19, 2009, 02:55:27 PM »
So I have a battery pack I use for not, it is 6V, has 4x AA batteries in it. But it wont power my roboduino unless it is plugged into USB. What battery pack should I get so I can run it without a USB being plugged in?
Offline galannthegreat
Re: Roboduino Battery?
« Reply #1 on: February 19, 2009, 03:03:18 PM »
if i remeber correctly there is a jumper that you can switch over to external pwr, or if not check the battery with a meter.
also is your battery rechargeable? if so try recharging it.
Kurt
« Reply #2 on: February 19, 2009, 03:47:08 PM »
It is not a rechargable battery.
Offline cooldog
« Reply #3 on: February 19, 2009, 03:56:02 PM »
just switch the power selector
-admin
favorite web sites
http://www.instructables.com/
Offline pomprocker
« Reply #4 on: February 19, 2009, 05:45:33 PM »
Yes move the jumper so that its connecting the middle jumper and the one FARTHEST from the USB that is next to the barrel jack.
On the place where the battery plugs in the center is for the RED (voltage) and the two outer headers are both grounded so it doesnt matter which way you attach your battery assuming it has a hitec connector.
« Last Edit: February 19, 2009, 05:46:39 PM by pomprocker »
« Reply #5 on: February 19, 2009, 09:02:12 PM »
Thanks guys. That took me a little while to find but I found it.
Offline pomprocker
« Reply #6 on: February 19, 2009, 10:34:25 PM »
Last post November 04, 2008, 10:24:39 AM
by Trumpkin
Last post December 31, 2008, 01:23:47 PM
by RoBoTicS
Roboduino
Started by offy Software
Last post February 19, 2009, 02:53:41 PM
by offy
Last post July 17, 2009, 04:30:39 PM
by RICEKING212
