Author Topic: Problems Reading Schematic  (Read 1600 times)
Offline Sam_CharetteTopic starter
« on: March 09, 2007, 09:20:55 AM »
Ok....
I picked up a basic stamp 2 IC, and decided to build my own programming interface.  It looks easy to do, but there's something that I don't get about the schematic.
The left is a serial import, the right is the BS2.  Two pins on the serial jack are jumpered together, two go directly to the BS2IC and the others have some capacitors.  It's these last two that are confusing me.
I can understand wanting a capacitor inbetween the source and the pin, but why would you connect those two via a capacitor as well?
« Last Edit: March 09, 2007, 09:22:18 AM by Sam_Charette »
The LED Massacre continues.  Death count is now 5
Offline Brandon121233
Re: Problems Reading Schematic
« Reply #1 on: March 10, 2007, 03:33:47 PM »
usually anything connected together with .1microF capacitors is just to reduce electoral noise in a circuit that could give bad readings from sensors or whatever, they don't usually affect the circuit they are just there to protect your components that are noise sensitive.
        —Thomas Edison
« Reply #2 on: March 10, 2007, 09:05:07 PM »
One of my coworkers said the same thing.  I just omitted them, as per his suggestion, since I don't seem to even have anything smaller than 1uF, and it works fine.
Last post July 13, 2007, 08:15:21 PM
by HDL_CinC_Dragon
Last post August 12, 2007, 08:27:20 PM
by osnap
Last post January 15, 2008, 02:26:53 PM
by paulstreats
Last post January 28, 2008, 09:19:53 AM
by Trumpkin
