Author Topic: Serial Communication Using VB 2005  (Read 2299 times)
Offline hendrachubbyTopic starter
« on: February 21, 2009, 02:41:12 AM »
How to connect serial port using VB and send ascii code to microcontroller ? I can do it with hyperterminal but i need to make a user interface using VB.
Thx
Offline daved
Re: Serial Communication Using VB 2005
« Reply #1 on: February 21, 2009, 01:37:31 PM »
Not using VB but am using C# to prototype a communications program to the Axon. Simply use a Serial Object and set all the params for the serial connection. Here is a listing for C#, it's very basic and should be able to be ported to VB with very little issues:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO.Ports;
using System.Diagnostics;
using System.Threading;
namespace SerialControl
    class Program
        static SerialPort sp;
        static byte[] reply = new byte[16];
        static void Main(string[] args)
            // initialize the serial port
            initSP();
            bool cont = true;
            try
                sp.Open();
                Trace.WriteLine("Opening the COM port");
            catch (Exception e)
                Trace.WriteLine(e.InnerException);
            // Just keep sending the same message over and over again
            // infinite loop
            while (cont)
                if (sp.IsOpen)
                    sp.Write("Hello Axon!");
                    Thread.Sleep(100);
                    sp.Read(reply, 0, 16);
                    string s = System.Text.ASCIIEncoding.ASCII.GetString(reply);
                    Trace.WriteLine(s);
                else
                    cont = false;
            sp.Close();
        static bool initSP()
            bool Success = false;
            try
                sp = new SerialPort();
                sp.PortName = "COM3";
                sp.BaudRate = 115200;
                sp.DataBits = 8;
                sp.Parity = Parity.None;
                sp.StopBits = StopBits.One;
                Success = true;
            catch (Exception e)
            return Success;
        }// initSP
Keep in mind I did this in about 2 minutes so there may be bugs, however it works.
« Reply #2 on: February 25, 2009, 10:25:00 AM »
We've been looking into this. Have a look at this thread:
http://www.societyofrobots.com/robotforum/index.php?topic=6711.new;topicseen#new
Last post May 02, 2007, 05:02:10 AM
Last post January 26, 2009, 02:13:34 AM
Last post January 11, 2011, 06:36:33 AM
by airuno2l
Last post September 18, 2012, 10:06:41 AM
by jkerns
